cool cool makes sense ill try the perpendicular thing as that is ez and probably will do the most good.
also FYI for crooper reason why im concerned is i got quite a bit more then 2 12s on 400w rms. im getting 2 15s ported and my amp puts out 3688w rms on 14.4v but that amp is goign to be connected to 2 16v batteries and a 225a alt runing 17-18v. But im also planning on fiberglassing the box to the trunk along with sealing the rear deck up as well so it should be air tight and if not realativly little bass will be able to enter the trunk
LinkBack URL
About LinkBacks
