I have been professionally designing speaker enclosures for more than 15 years and I am constantly annoyed by the confusion that surrounds this topic. The problems with busting the myths that surround this are that you can not rely on either the rated
power out put of the
amplifier or the thermal limitations of the sub. In the real world both of these specifications are at the mercy of a number of variables. You can measure the out put of the amplifier in order to eliminate that variable but you must understand that the speaker has been rated by approximation. You can play it at RMS power indefinitely but any thing over that for an extended period of time may lead to enough heat to cause thermal melt down. A common misconception is that this only happens at the speakers max rating. Not true. That’s a fact.
The next but not least significant element is the speakers suspension. Even if the speaker is underpowered and never reaches its thermal limitations it can still easily be damaged due to over excursion. Excursion is not a direct result of input power and dose not necessarily result in more output. Also a fact.
And not even close to least, most manufacturers build subs with obese inefficient motors and then under rate the thermal limitations. Think about it if you where a manufacturer with millions on the line what would you do?
The problem here is not the manufacturers approach, it’s the testing approach. Lets say that you feed a 500 watt sub 800 watts in a .25 cubic foot sealed enclosure for 10 hours and nothing happens. You haven’t proved anything. That sub might be able to take 850 watts for 9.5 hours before melting down. The point is that you don’t know if the sub is under rated, or over rated, or if your amplifiers particular design causes unexpected levels of heat in the clipping stage. You cant prove anything in a test like this with out accounting for every variable. And the day that I see some one with the resources and the time to write a 20 page report on the definitive answer to this topic I will have to point out that they have one hundred thousand amplifier/sub combos left to test not to mention the sub/enclosure combinations and that they have effectively proved nothing.
If you want to be safe stick to the numbers and power your speakers with the RMS rating. If you want to push the edge of performance you take the risk of exceeding the thermal limitations of your speakers. If you have an education in speaker design you can predict and push the limitations to new levels and only blow something up once in a while. Its life deal with it!
