Results 1 to 10 of 10
Thread: double din headunit with vga input
    Jun 2003
    Hi,
    Looking for a double.din sized headunit, something like the Pioneer AVIC D3 with amp and gps but also vga-input so that I can use it as a pc monitor but I need it to be vga since s-video quality is not good enough...
    Is there such a unit available that fits a double-din frame?
    I do not want to use a car-pc monitor like the lilliput or simular because I need the headunit to support gps, radio without using the pc.
    I plan to use the pc to monitor my car using custom applications so that is the reason for requiring vga-quality...
    /L-O
    Elsewhere
    It ain't happening.
    What you want doesn't exist.
    How about the Wiki?
    Jun 2003
    Hmm,
    It is sad really but the closest thing would be to combine a 1-din headunit which uses an external monitor to display navigation output etc and I could use my 1-din flipout vga screen to act as both pc-montor and hu-nav monitor...
    Thanks for the reply!
    /L-O
    Mar 2006
    Colorado, but Canadian!
    I dont see why you want a headunit to do all that stuff. A PC can do it better and faster. Then you can just get a regular screen, and run your stuff through it.
    I guarentee that no matter how quirky your application a 1 PC setup with 1 monitor and no HU will work, and in my opinion be best.
    1.9in x 2.9in -- 47mm x 73mm
    Jun 2003
    Thanks again guys!
    To update the story just a bit, I have been on the forum for quite a while and I have ad the carpc up and running fine with navigation and playing mp3s but it is another story trying to get the pc to handle bluetooth devices for handsfree phonecalls like an oem unit can.
    I have managed to get the pc to work partially but the software that is available today: phoneco and freephone does not work good enogh with my MS Phone Qteq S100.
    The oem systems I have tried works much better and the pairing is quick with the Qtec phone so I still want to use the pc for some things but not others like handsfree...
    /l-O
    MySQL Error scott_fx's Avatar
    Dec 2004
    Los Angeles Ca
    there is a kenwood or alpine headunit that was hacked a while back. you may want to do a search on that
    New System in progress:
    M10k
    Phaze TD1500 ~> Seas g18rnx/p
    Zapco Ref 500.1 ~ 12" tc-9
    Transflective Xenarc
    My Car Pc Install
    My Boat Pc worklog
    Jul 2006
    new york
    check this out its a double din with vga and usb touchscreen ready....
    http://www.revo-sys.com/bonz__65_inc...pc_monitor.php
    Mar 2007
    has anyone tried this unit yet?
    the site doesnt have much details on the amp
    It looks kinda sketchy
    Elsewhere
    Hey, look at this: http://digitalww.com/store/proddetail.asp?prod=DWW6500
    It's the same model and has been sold by DigitalWW for nearly a year.
    Search for DWW-6500 on these forums and find peoples' opinions.
    How about the Wiki?
    FLAC Dougw133's Avatar
    Nov 2007
    PA
    Thats what I was about to say...I have seen this DWW Screen on about 50 web sites under different names.
  1. 8 inch Widescreen LCD in double Din
    By Dimlow_UK in forum LCD/Display
    Last Post: 11-06-2007, 07:31 AM
  2. DOUBLE DIN Dilemma
    By BLAXKINNED in forum LCD/Display
    Last Post: 02-04-2007, 04:03 PM
  3. LCD screen size for double din opening...???
    By EclipseGSturbo in forum Newbie
    Last Post: 01-30-2006, 01:24 PM
  4. Double Din to Single Din
    By loganm in forum General Hardware Discussion
    Last Post: 03-20-2005, 10:58 PM
  5. double din adaptor? 2 1-din devices in a double din space possible?
    By ucidave in forum General Hardware Discussion
    Last Post: 09-17-2004, 06:10 PM
