Results 1 to 3 of 3
Thread: amp trouble?
    Nov 2007
    amp trouble?
    well im new to the forums and i was wondering if i could get some help. i tryed to search but couldnt find anything on my problem.
    i have a 2000watt pyle amp at 4 ohms and its not powering completly. when i put it to my power source it goes directly into safe mode. ive checked every connection and wire 5 times over. ground power remote everything. havent a clue on why it dosent work. i tryed the amp on my friends system and it did the same thing. any help? ideas? i checked the fuses as well and my friend says it could be an internal problem.
    Nov 2007
    Broken amp.
    Moral of the story: Don't buy Pyle.
    JAC is offline
    Low Bitrate JAC's Avatar
    May 2006
    North of NY
    Have you gotten the amp to work?
    If not here's my suggestion... You've probably already covered this.
    1st- Make sure the lead wire(+12) is of 8-guage. Your acc wire can be a small splice to the +12 lead for testing for now(nothing smaller than 16g).
    2nd- Make sure ground wire is the same gauge and not longer than 6-inches and mount it to the chasis and keep it away from all other sources, ground atleast a foot or a foot and a half away from other devices so as not to introduce any amp noise.
    3rd- Make sure for safety to have a fuse as close to battery as possible on lead wire
    (6 inches or less).
    4th- If the car is on (idle) while your testing meaning (your bat voltage is higher than 12.0v's you should have no problems). Some amps work better with higher voltages. (examples 12.9/13.6 and so on).
  1. Engine Noise due to ground loop or amp?
    By matt11601 in forum Car Audio
    Last Post: 08-26-2009, 08:38 PM
  2. Replies: 6
    Last Post: 03-20-2007, 10:16 PM
  3. Amp running hot...??
    By Emerica2843 in forum General Hardware Discussion
    Last Post: 02-08-2006, 05:40 PM
  4. Replies: 3
    Last Post: 12-07-2004, 06:34 PM
