Page 2 of 2 FirstFirst 12
Results 11 to 17 of 17
Thread: MECA 2007 Finals Pictures
  1. #11
    _
    Mar 2004
    Little Elm, Texas
    that's only allowed in MECA (the front windows).
    It's to prevent a judge from fixating on something and thus pulling the stage.
    if you can prevent the judge from seeing out, they cannot be distracted and cannot fixate on a point as easily.
    Again, it's only allowed in MECA, not IASCA or USACi.
    We use acoustic foam in the rear windows of our car. That IS allowed in all orgs. In all reality, it's no different than if we were to build a wall of woofers in the car. Only this actually helps improve the imaging in the car.
    Jan Bennett
  2. #12
    Maximum Bitrate boomintrac's Avatar
    Apr 2005
    2hr west of Chicago
    Hey darrin sounds like it was a good show, mabye next year Ill be in the lanes with ya.
    Aron
    Absolutely 100% stock
  3. #13
    Maximum Bitrate Megalomaniac's Avatar
    Jan 2006
    The Colony, TX
    Quote Originally Posted by RedGTiVR6 View Post
    ive seen people put acoustic foam on dash instead of a dash mat. but then it begins to look ugly since the foam is soo thick, but they swear by it that it brings the stage up drastically. i never heard of the back window thing you mentioned
    screen name here use to be MegaloRESE15"
  4. #14
    _
    Mar 2004
    Little Elm, Texas
    we used to have a huge dash mat...it doesn't matter what it looks like when you're being judged for sound...the whole point is to get the best sound possible.
    Jan Bennett
  5. #15
    Car Audio Moderator durwood's Avatar
    Sep 2006
    Chicagoland (St. Charles,IL)
    Quote Originally Posted by Megalomaniac View Post
    sorry for newb question, but why are windows covered?
    This was the first time I had seen it too and asked about it. It was excatly as what RED said, so the judges are not distracted. I think it's hogwash. Most good judges I know clsoe their eyes when listening anyway. If they were really that worried about it I'd just offer a blindfold/sleeping mask thing.
    Quote Originally Posted by boomintrac View Post
    Aron
    Sweet! Aaron I think you should, we need some more IL SQ cars represented. I'm sure Zapco would definitely support you if you haven't already looked into it.
    As far as dash mats, I'm not sure I believe they have any bearing on dash reflections, but it soley depends on the car. If your dash is hard plastic, then I can see it making a difference, but if you dash is squishy (like mine) it's not really going to do much IMO. Plus it depends on your speaker mounting locations, but the window is going to do more damage then your soft dash ever would. It's all about hard and soft surfaces and how to determine what's really affecting your sound.
  6. #16
    _
    Mar 2004
    Little Elm, Texas
    it does make a difference. Even with a soft dash.
    It's the non-absorbant surface that causes the problems.
    It's minute, but it's what make the difference between first and second some times.
    We've spent hours playing with our dash mat configuration.
    First it was a big, puffy mat to help even out the dash and eliminate the issues that were presented with the gage cluster hump. Now it's just a single layer with foam in the corner where the window meets the a-pillar.
    It's firmed up our imaging a great deal compared to before, as has the rear foam.
    Also, we notice a difference when we fold down our visors, cuts down on reflections there.
    It's all about knowing how to PLAY the reflections in a car, not necessarially eliminating them. Hince the reason we have our tweeters and 3" mid-range drivers facing the windshield...because we took the time to position them and to mess with cutting down, or moving the reflections.
    Jan Bennett
  7. #17
    Sep 2006
    I believe it could make a difference in some cars, but I've seen way too many people using them just to use them. If you have dash mounted or a-pillar mids/tweets, then yes it could make a difference, but in some cases it won't do anything except on the pyschoacoustic level.
    I've never used one nor will I because the only reflections causing any issues if it's even an issue is the side windows in my car (but this where it's car dependent). Actually the side windows are what helps my car apear to have a wide soundstage (thank you early reflections). Folding down my visor does not alter the sound one bit in my car. In your car I could see it making a difference because your mids and tweets are mounted in the pillars, mine aren't. Again, just pointing out it's car dependent.
  1. Replies: 72
    Last Post: 07-19-2008, 12:28 AM
  2. GoogleEarth GPSR Tracking
    By briefnotion in forum GPS
    Last Post: 09-11-2007, 08:32 PM
  3. Indexing music in 1.0.9.8 Failed
    Last Post: 07-07-2007, 12:19 PM
  4. Pictures from CES 2007
    By RedGTiVR6 in forum General MP3Car Discussion
    Last Post: 02-03-2007, 07:45 PM
  5. USACi World Finals Pictures
    By RedGTiVR6 in forum Off Topic
    Last Post: 10-19-2005, 10:14 AM
