That's the first thing to cheack and avoid. In no situation should you be going from one amp feeding into another amp.and I guess through the factory amp.
Remove the capaciator.and a Micro Farad Capacitor.
Yes, per above you should never be running a high power output into a factory amp.Could this possibly be a problem with feeding too much power from my setup to the factory in vehcile amp?
What you want to do is locate you factory amp. Cut the wires at the speaker output ends, feed them into the 360, 360 to amps, amps direct to speakers, NOT BACK TO FACTORY AMP.
If you're still having troubles I highly recomed you stop the install, rempove all your added on equipment and have it professionally installed before you blow something up - thoguh I;d be surprised if somethign isn;t already permenantly damaged.
LinkBack URL
About LinkBacks
