Results 1 to 9 of 9
Thread: Alpine iDA-X001 - Good choice?
    Sep 2007
    Corona, Ca.
    I am updating the stock head unit in my 2000 Jeep Wrangler to intigrate with my car pc. Anyone know of any reason the iDA-X001 would not be a good choice? I will not be running any external amplifiers, just the head unit.
    Getting quality goods and service is like buying oats. If you would like clean, fresh oats you must pay a fair price. If you would like oats that have already been through the horse, those are a little cheaper.
    Maximum Bitrate boomintrac's Avatar
    Apr 2005
    2hr west of Chicago
    I think it will work great for you, you will still have ipod control and be able to use the ainet input for the pc.
    Aron
    Absolutely 100% stock
    Sep 2007
    Corona, Ca.
    I don't really understand how everything functions together, but I will be running StreetDeck as my front end. If I plug in an IPod to the head unit will Streetdeck see it and put the music info on the PC display or should I plug the IPod into the PC instead? I am considering using an IPod as a removable hard drive instead of keeping all my music on the PC hard drive. That will make my music easily portable. Any thoughts on this?
    Elsewhere
    Quote Originally Posted by JLemieux View Post
    The only connection the PC will have to the headunit is an audio signal.
    Using that logic, how could the PC display any information about the iPod? It can't, since the iPOd isn't connected to the PC at all.
    In order to see anything from the iPod on your PC, the iPod needs to be connected to the PC.
    That said, if you have a PC with lots of music loaded up on it, why would you need/want the iPod?
    Well, that answers that question.
    It will work OK, but if you have a single USB issue at any point, you're going to end up being without music.
    Personally, I think the better scenario would be to have your music saved on the PC's HDD and then add what you want to the iPod whenever you want.
    How about the Wiki?
    Sep 2007
    Corona, Ca.
    This Alpine head unit has an lcd display on it. I thought maybe there was some way to (easliy) output it to the pc. No big deal if it can't. I saw an interface called Car2pc. Would that help me?
    As far as having the IPod, I guess just having the transportability of all my music apealed to me. Also, since this pc is in a Jeep, I think someday I will damage the hard drive with all the bumps and banging around it gets. At that point I could just plug the IPod back into the head unit and still have music for the long drive home.
    Maybe I am over thinking this whole issue.
    Elsewhere
    All it will do is allow you to send commands to the PC for the purpose of controlling the PC.
    I think you're over-thinking.
    The question of hard drive durability has beeen hashed and rehashed here for years and there is no foregone conclusion about it.
    One member used the same HDD in two vehicles, both in accidents that incurred frame damage. The HDD still works... (Right TruckinMP3? )
    I understand the appeal of music portability.
    As I said.. It will work for you, certainly.
    I guess I see the PC in the car as a means of having access to as much music as I want and an iPod (or similar device) as a means of taking a portion of that music with me when I leave the vehicle.
    Just because I see things differently than you doesn't mean your ideas are better or worse than mine. they're just... well... different.
    How about the Wiki?
    Sep 2007
    Corona, Ca.
    I appreciate the feed back. For now I'll put the music on the hard drive and enjoy the cool features of Street Deck. Thanks.
    One last question while I'm here. I, have the beginner pc from MP3Car. It has an audio out jack and RCA outputs. Which is best to output audio to the head unit? Or does it matter? Thanks again for the help.
    Apr 2005
    2hr west of Chicago
    eitheir will work fine, but if it were me I would do use the RCA out ans it is one less connection in the chain.
    Aron
    Sep 2007
    Corona, Ca.
    Thanks for the help.
  1. Indexing music in 1.0.9.8 Failed
    Last Post: 07-07-2007, 12:19 PM
  2. Hardware Review: Car2PC Alpine MBUS review
    By MatrixPC in forum The Review Palace
    Last Post: 06-02-2006, 07:39 AM
  3. Microphone review. Might be a good choice for in car.
    By Defiler in forum Input Devices
    Last Post: 11-11-2005, 01:16 PM
  4. Is the Asus Digimatrix a good choice for CarPC?
    By m3evolution@hot in forum Newbie
    Last Post: 07-25-2004, 07:09 PM
  5. Sproggy PS is not a good choice..
    By THEMP3KID in forum Power Supplies
    Last Post: 07-18-2002, 09:04 AM
