Results 1 to 8 of 8
Thread: foobar2K might be possible in roadrunner
    Sep 2006
    Flanders - Belgium
    I've just found out there's a plugin for foobar2000 that emulates the winamp API and translates it to the foobar2000 API, its called foo_winamp_spam. Just google for it and you'll find it in the top links.
    Since i don't have Roadrunner installed, i'm wondering if someone would like to try if it or if it's known already.
    Jul 2006
    im gonna look into this. apparently using foobar with asio (i honeslty have no idea what it means) can eliminate issues with the voices being corrupted while using the kx drivers.
    FLAC Machinehead's Avatar
    Jun 2007
    hijacks small portable city
    I'll have to try it out. Foobar2000 is so much better than winamp.
    Car Audio Moderator durwood's Avatar
    Sep 2006
    Chicagoland (St. Charles,IL)
    well if enough people voiced their opinion in the roadrunner forum, then it might be possible to use foobar without this extra added application. I know I have asked a few times myself in couple of threads, but it went un-noticed.
    But now that rooadrunner no longer has to rely on winamp, i.e. FMOD player is also an option, then I'm not sure what would be needed to allow foobar to be used as well.
    Constant Bitrate Felix509's Avatar
    Feb 2007
    Lafayette, LA
    Oooohhh, YES, FooBar in Roadrunner would make my Day! Proper resampling and the other nifty features..
    Maybe we could start a Thread with a running list of people who want Foobar in RR..
    Ours is the age that is proud of machines that think and suspicious of men who try to.
    ___________________________________
    Current SYSTEM
    AMD64X2 2.5
    Xenarc
    ZAPCO DSP-6
    ARCAUDIO SE Amps
    Rainbow Profi CS365 & Profi Vanadium 12"
    Sep 2006
    Well I couldn't find th thread I thought was out there, but I found another recent one that had some not so good news.
    Problems starting 9-2-07 version
    So maybe this will be the only key for now. Has anyone tried it yet?
    Jun 2007
    Quote Originally Posted by Felix509 View Post
    And software audio tuning.
    Jun 2007
    Quote Originally Posted by durwood View Post
    Well I just gave it a go on my desktop. Play, pause and stop seem to work fine, as well as exiting the program and resuming where you left off. Next track and previous track skip all over the play list, no rhyme or reason. It only displays the current track and just repeats that track in the play list. You can't add to the playlist at all. And foobar has to be loaded manually, which I kind of expected anyway.
    Seems like this doesn't do the job.
    I did use the beta version for foobar2000 0.9. I'm not sure if the old version for Foobar2000 0.7 and 0.8 would work any better.
  1. How to setup iGuidance GPS for RoadRunner
    By MatrixPC in forum RR FAQ
    Last Post: 05-22-2009, 09:29 AM
  2. Replies: 13
    Last Post: 08-30-2007, 10:27 PM
  3. Roadrunner as shell reloads when shutting down
    By Konrad in forum Road Runner
    Last Post: 07-11-2007, 01:49 AM
  4. Roadrunner Skinning Tutorial
    By Meelobee in forum RR Skins
    Last Post: 12-30-2005, 08:28 PM
