Results 1 to 4 of 4
Thread: 06 sonata aux/mp3 input questions
    Dec 2007
    Hello everyone. I'm a new member to this forum and I have a few questions in regards to the 06 hyundai sonata. I'm purchasing the car within the next couple of days and I just discovered that it does not include a auxiliary input/mp3. I have a ipod and im looking to use it while im on the road. I know that getting a new head unit and fm transmitters are alternatives but from what I hear the sound quality is much better when using the aux input and it might be cheaper to just install the aux switch alone, as oppose to getting a new headunit. So here are my questions:
    1. What would I need to install the aux input?
    2. What is the price for the product?
    3. Is it worth it to just get a new head unit?
    Any and all advice will be greatly appreciated.
    Thanks!
    Jim
    Mar 2007
    It all depends on the quality of the fm transmitter, head unit, and etc.....go see some professional shops to see if an off the shelf hu would work for you or if the sonata has some high end sound system you might need to change the whole speaker setup...so in that case a hard wired fm transmitter(connects right to the antenna cable) might be woth a try (40$), thats what i had to do in my 95 maxima because of the BOSE Head unit....(worth a small fortune at the time)
    Car Audio Moderator durwood's Avatar
    Sep 2006
    Chicagoland (St. Charles,IL)
    Jan 2008
    I will vote a FM Transmitter , becasue it is easy to use/install and more fliexable.It also cheap. For you case , if your car audio don't have any aux/line-in port , you need to replace it with some module.
    http://www.cross-mark.com/display-ch...pod-p-706.html
    http://www.amazon.com/VR3-MP3-PLAYER...679606&sr=8-13
  1. Frequently Asked Questions
    By bgoodman in forum The FAQ Emporium
    Last Post: 05-03-2005, 07:25 PM
  2. audiocontrol three.1 input questions....
    By kaptan in forum Car Audio
    Last Post: 01-04-2005, 07:41 PM
  3. Many Questions, seeking input ;)
    By aBs0lut30 in forum Newbie
    Last Post: 12-14-2004, 06:12 PM
  4. Replies: 3
    Last Post: 02-08-2002, 12:25 AM
  5. pioneer IP-BUS input questions
    By mp3pc in forum General Hardware Discussion
    Last Post: 09-04-2000, 04:32 AM
