A few things to check:
Is your Touch screen powered form the cig lighter outlet? May need to power and ground from same place as computer is.
Is your USB cable running alongside power cables? If so the 12V may leak into it.
May need a higher quality USB cable with better shielding..
Just to test, with the car running where you can hear the Alt whine, move the USB cable around to see if the Whine goes away/gets louder. May just need to relocate this cable..
LinkBack URL
About LinkBacks
