Results 1 to 5 of 5
Thread: Is it OK to ground my PC to the Head Unit Ground wire?
    Nov 2007
    Hello all,
    Im putting together my first CarPC, and I'm about ready to install everything. I plan on leaving my head unit installed and running the computer through the auxillary in port of the head unit.
    I've read some posts about ground loop noise, and I was wondering if I can avoid all that by just grounding my CarPC to the ground cable on the back of my head unit. Has anybody done this? (yes i did a search for this very thing on the forum) or is this a bad idea?
    Any feedback is appreciated. Thanks.
    Maximum Bitrate XxAndyxX's Avatar
    Dec 2003
    Edmond, Oklahoma
    Make a good metal contact on you car, and ground to that. I wouldn't ground anything to the frame of the head unit.
    Mar 2006
    Colorado, but Canadian!
    I think he means the itty bitty wire that goes to a ground from the HU correct? If so, then the answer is no. Way too small of a guage. But trace that wire down to the chassis, make sure it is free of crap, and ground there.
    1.9in x 2.9in -- 47mm x 73mm
    Nov 2007
    Quote Originally Posted by 2k1Toaster View Post
    That is correct, and hey, great idea on just tracing it down to the chassis, for some reason I didn't even think of that, I will do that, as long as I can trace the wire. Grounding in the same spot should eliminate and ground loop noise issues correct? (Still have to worry about RF interference and such though.)
    FLAC greatwhite's Avatar
    May 2007
    Top o' the world Ma!
    Quote Originally Posted by cbutters View Post
    Maybe, but not always. Grounding to the same point as the HU is a good start.
    Try your install first and see where it goes from there. What you're trying to do with a common ground is equalize the "affinity" to ground so one component is not trying to ground through another thus inducing noise.
    Ground loops can crop up for the weirdest of reasons sometimes...............
    Leonardo Da Vinci
  1. Seat Ibiza Mk4 Alana Head Unit - need sound in!
    By onlineamiga in forum General Hardware Discussion
    Last Post: 02-11-2007, 06:02 AM
  2. XM-Ready head unit software integration?
    By TaZMaNiaK in forum Software & Software Development
    Last Post: 04-02-2005, 06:23 PM
  3. using head unit to control/display from pc...
    By vincerules in forum General Hardware Discussion
    Last Post: 01-23-2003, 06:18 AM
  4. Easy head unit question, and PC to amp question.
    By dudah85 in forum General Hardware Discussion
    Last Post: 09-09-2001, 04:57 PM
