Results 1 to 6 of 6
Thread: Few small bugs... please help!!
    Dec 2007
    Ok, so I got my sub up and bumpin in my Civic type R
    Alpine type r 12 and pheonix gold amp, with some alpine mids in the back.
    It pumps real nice, but I have a couple questions.
    I tapped into the back speakers using the RCA/line converter.
    For my remote wire I just put a small wire from my + pos terminal on the amp, stright into the remote term on the amp.
    Now the light on the amp is constantly on, witch would be draining my battery while my car is parked right?
    Also, when my car is off I can hear some mumbling or feedback kind of .. coming from my sub. Sort of popping noise.
    Any idea how I can fix these two problems
    Thanks for the help!!
    Ntox
    Constant Bitrate Felix509's Avatar
    Feb 2007
    Lafayette, LA
    The Remote in on the amp needs to be switched 12v that goes off when the key is off..
    DO you have a computer or after market Head Unit? If so then they should have remote outputs that are switched..
    Ours is the age that is proud of machines that think and suspicious of men who try to.
    ___________________________________
    Current SYSTEM
    AMD64X2 2.5
    Xenarc
    ZAPCO DSP-6
    ARCAUDIO SE Amps
    Rainbow Profi CS365 & Profi Vanadium 12"
    Dec 2007
    Im using my stock deck...
    Any other sudgestions?
    Feb 2007
    Lafayette, LA
    You can look in your fuse box and pull the 12V from the radio fuse and run it to the amp's remote turn on for a quick fix.. .
    Current SYSTEM
    AMD64X2 2.5
    Xenarc
    ZAPCO DSP-6
    ARCAUDIO SE Amps
    Nov 2007
    yeah, your remote needs to be switched or it will kill the batt. fixing that will end the popping.
    Dec 2007
    Awsome.
    This site is kick ***!!!
    thanks
  1. WTB - Small, VERY Small Computer
    By ukchris in forum Classified Archive
    Last Post: 02-06-2007, 04:38 PM
  2. FS: Small Form Factor PC, Ultra Small Form Factor Motherboards
    By NiteMax Mark in forum Classified Archive
    Last Post: 01-23-2007, 03:52 AM
  3. What is best: small epia1000 or big p4 2.2
    By xpluis in forum General Hardware Discussion
    Last Post: 11-30-2006, 08:48 PM
  4. Need a very small 12Volt regulated PS 60 mA min
    By rotarypower101 in forum General Hardware Discussion
    Last Post: 04-19-2006, 05:33 PM
  5. small motherboard
    By crazybat in forum General Hardware Discussion
    Last Post: 12-17-1999, 09:14 PM
