If it happens to be a problem with the RCA wire a couple of ways to test that out is to simply switch the RCAs from the noisy one to one that is not as noisy. This should be done at the amp leads or the leads at the HU. There is a possibility that the problem may occur at the amp itself or the deck. In one particular situation I've seen the amp seemed to create noise in one speaker. Upon further investigation it happened to be a bad channel on the amplifier. So starting off by switching the RCA leads will help to determine that.
LinkBack URL
About LinkBacks
