Results 1 to 10 of 12
Thread: remote turn on for amps
    Dec 2007
    okay here is the main question i have at this point, right now i have a pioneer avic-n2 that i am going to sell, when i do im going to put in an lcd and my compaq laptop, now i know how to hook up the rca cables but how do i connect the remote turn on for the amps? The wire from the headunit that tells the amps to turn on. Is there another wire i can use or maybe something off the gm harness that i wont be using?
    Jan 2007
    East Central FLA
    You can run a relay off whatever will be powering the computer
    Dec 2007
    Quote Originally Posted by lbridges View Post
    well its a laptop so im going to be using a belkin auto/air to power it, but i am going to use an m2 atx to power my xbox, i can run the remote wire off that?
    Variable Bitrate walstib's Avatar
    Jul 2005
    Atlanta, GA
    Pins J6 on M2-ATX, see the manual for details.
    Carputer Project Status:
    0% - Mobo died on 2/17/08
    Check out the worklog for my '01 Pathfinder.
    Jan 2007
    East Central FLA
    Quote Originally Posted by tacobandit View Post
    See post above, but also whatever will be triggering the auto/air plug to go hot could also trigger the amp.
    Nov 2007
    any keyed 12v source will turn the amp on. find something that is controlled by the key and tap into it.
    Dec 2007
    okay so i got my m2-atx today and i am looking it at, the manual says that the left pin is RMT and right is the ground. So i have to ground the pin itself?
    Oct 2006
    im wondering the same thing. any help?
    95 Mustang 5.0
    Custom Case, VIA m10000, 512 MB, 80gig, M2-ATX, Slot Load DVD, 7" LCD Touchscreen
    80% done
    Dec 2007
    well i couldnt get it to work either way, so i used the 12v wire from the radio to power it, i installed a switch so that i can turn the amps on/off so i wait until the computer has loaded before i turn it on
    Newbie Rad333's Avatar
    Mar 2008
    Chicago
    I'm turning my amp on using the j6 jumper on a m2-atx and I don't have the ground pin hooked up to anything. The RMT pin runs straight to the turn on lead on the amp. It works great; The m2-atx delays turning on the amp for a couple seconds so you don't get any amplifier pop when it turns on.
  1. Replies: 2
    Last Post: 02-20-2007, 11:21 PM
  2. Can I use a Remote Turn On from Head UNit to power Motherboard?
    By whosyourdady08 in forum General Hardware Discussion
    Last Post: 12-12-2005, 09:44 AM
  3. Can I use a Remote Turn On from Head UNit to power Motherboard?
    By whosyourdady08 in forum General MP3Car Discussion
    Last Post: 12-11-2005, 09:18 PM
  4. remote turn on lead from headunit to power up PC
    By BluCivic93 in forum General Hardware Discussion
    Last Post: 07-27-2000, 03:13 PM
