Per your current wiring, maximum continous RMS output is 250 watts.whats the rms output of my sub atm with that set up can anyone tell me
Correct. Your amp is not designed to run at 2ohm bridged. Doing so could damage it.now the amp says its 2-8ohm STEREO stable so does this mean that i CANT wire it to a 2ohm mono?
PS that 4ohm mono bridged rating of 3700 watts is a typo. In theory I'd expect a max continous RMS output of 415 watts x1 (bridged). Which means some of the other ratings are bogus. I.e. I'd expect 2x 207 RMS at 2ohm, but the 4ohm spec may be right.
LinkBack URL
About LinkBacks
