Results 1 to 2 of 2
Thread: I think i blew my speakers...not sure
    Apr 2005
    Northern Virginia
    So I had my carpc working just fine for 2 years, but the mobo blew out, and in the midst of swapping mobo's, the connectors did that loud crackling when you first plug in audio cables. This happened a few times.
    When i reinstalled my 10band EQ (webEQ), it worked fine, but randomly on a restart the top 3 frequencies were maxed out, and i played a full song before I realized it.
    Now i hear crackling when playing about half my songs, and then all my songs sound hollow, as if some of the frequencies aren't there. Its more noticeable on my front speakers than my rear.
    setup: 4channel alpine amp, 6.5" pioneer 4ways up front, 6x9" pioneers in the back.
    I think the rear ones are less noticeable because I assume that larger speakers handle distortion and random wattage spikes better (but I only assume).
    My friend told me that it could be bad wiring, but everything sounded fine for the last 2 years, and no problems till now. He said it could also be the amp, but I don't know, the fact that it was due to the wattage spike/high EQ setting...im not sure. I feel like its the speakers blown out.
    Thats why i'm asking you guys, who deal with speakers and installs much more than I do. What do you guys think? I'm gonna use tester speakers and see how it works later this week, but I just wanted to get some advice from the pro's, Thank you.
    Nov 2007
    Yeah test the speaker first.
    If you have a multimeter handy, set it to read ohms and connect to your speaker wires.
    You can also check to see if you have blown a speaker in the audio system by using the DMM to measure the speaker's impedance, or resistance. The dial should still be set to Ω and the red lead will be connected to the positive terminal of the speaker and the black lead goes to the negative side of the speaker. Most speakers should have a resistance of 4Ω . and the impedance is often stamped on the back of the speaker's magnet. A badly blown speaker will usually read under 1Ω .
    http://www.boostcruising.com/forums/...howtopic=61739
  1. 2-Channel Amp---4 Speakers
    By korek28 in forum Car Audio
    Last Post: 07-14-2011, 01:36 PM
  2. FAQ: Why not Home PC speakers for the car?
    By RedGTiVR6 in forum The FAQ Emporium
    Last Post: 03-08-2010, 09:44 PM
  3. Front Door Speakers in a BMW 3 Series
    By ajdale in forum Car Audio
    Last Post: 08-05-2006, 09:55 AM
  4. Rear speakers not going :(
    By samael in forum Car Audio
    Last Post: 08-13-2005, 03:33 AM
  5. Replies: 12
    Last Post: 10-28-2004, 07:44 PM
