Page 2 of 2 FirstFirst 12
Results 11 to 18 of 18
Thread: Total amp draw and 2 fuses.
  1. #11
    Feb 2007
    Kenora, ON, Canada
    B+ Test Voltage: 14.4 VDC
  2. #12
    Oct 2006
    Las Vegas
    here's another way to figure it out with a calculator
    http://www.bcae1.com/images/swfs/sys...nassistant.swf
    be sure to select the class inside the amp, in adition to entering the efficiency.
    It provides a bunch of other useful info like wire size. The link at the lower right will show some more of the theory behind it.
    I totally spaced out efficiency. Good explanation on the 2 fuse thing.
  3. #13
    Nov 2007
    you guys are going about this the wrong way. the fuse at the batt is to protect the car. you fuse the wire, not the device. so if your running say a 4awg wire max fuse at the batt should be 125 amps. go up a size to 2awg and the max fuse rating is 200 amps. so the man fuse should be fusing just the wire where as the fuses on the amp actually protect the amp itself.
  4. #14
    Oct 2006
    Las Vegas
    you're right, lets just assume a wire and fuse it.
    I think the gist of the previous calcs was for a deeper understanding of the device fuses (which was a question of his in the second post), and a means for a confident determination of the wire size to the amp based on it's current draw, which would be protected as you have so eloquently and kindly stated.
    If you look through pokki's posts again, he has already stated that, and it's well covered in the link I provided.
    No one likes a guy coming in, reading half of the thread, missing the relevant info, and telling everyone they're "wrong". Have a nice day
  5. #15
    Mar 2006
    Colorado, but Canadian!
    Quote Originally Posted by brendonius View Post
    Ahhh thanks Pokki...definately totally left out efficiency in the equation. Performance verification sheet says 65.546%...damn thats not very efficient.
    So...
    P = V*I*(efficiency)
    P = (14.4)(60)(0.6546)
    P = 565.57= 566W RMS.
    According to rap sheet:
    240W RMS @ 4ohms
    393W RMS @ 2ohms
    why such a big discrepancy?
    Ok, very simple...
    1179W x 65.46% = 771.77W actual.
    Most cars run at 13.8v. Some run at 14.4 but usually those are very sepcial cases.
    So 771.77W / 13.8V = 55.93A maximum draw. So 2 fuses at 30A in series make perfect sense.
    1.9in x 2.9in -- 47mm x 73mm
  6. #16
    Oct 2006
    Las Vegas
    Quote Originally Posted by 2K1Toaster
    we all know you meant parallel, it's ok.
  7. #17
    Mar 2006
    Quote Originally Posted by h3rk View Post
    Shhh... My brain hasnt turned on yet.
  8. #18
    Feb 2007
    Kenora, ON, Canada
    hahah...damn thanks for the help guys...it definately makes a lot more sense now.
