Results 1 to 10 of 18
Thread: Total amp draw and 2 fuses.
    Feb 2007
    Kenora, ON, Canada
    Hey guys...sorry for the odd title..couldn't think of something good for this.
    I have a rockford fosgate p325.1 for a bass amp and i was just looking over how i could make it a little bit safer (ie. make sure it is properly fused in both front and back of vehicle.) The amp has 2 onboard fuses of 30A a piece. Now my question is...does that mean this draws 60A total? or is that just a double safeguard in case the first one doesn't give out in time. Any way to figure this out?
    Mar 2006
    Colorado, but Canadian!
    P=V*I
    Power = Volts * Amps
    So if it is a 1380W amp, and the car runs at 13.8v, then it draws 100A at most. The problem comes from that wattage. A $10 4000W amp isnt going to draw 4000W, it is just marketing. But looking at the manual you should be able to figure out actual draw.
    1.9in x 2.9in -- 47mm x 73mm
    Feb 2007
    Kenora, ON, Canada
    Going by the performance verification sheet then...
    240W RMS @ 4 ohms
    1179W Max
    therefore,
    1179 = 12 x I
    I = 1179/12
    I = 98.25A MAX
    or
    I = 240/12
    I = 20A rms
    Going by this...i'm not quite sure if i understand the purpose of 2x30A fuses. Obviously maxing the amp out at 1179W isn't going to happen because both fuses would blow. Should i replace them with 2x50A to leave some overhead in case it ever did max out?
    Feb 2007
    Kenora, ON, Canada
    ****...just realized its not 12V exactly...assuming my car puts out 14.4V its still around 80A max for draw. Still over and above the fuse rating...yet i've never blown a fuse.
    Oct 2006
    Las Vegas
    another way to find the amps is to substitute ohms law for voltage in the power equation.
    since P = I * E
    and E = I * R
    P = I * I * R = I^2 * R ( I squared R)
    then you can find the current based solely on the load resistance and rated power.
    that way you don't have to make rough estimates on voltage.
    EDIT: But I still cant get it to wrk out to need two parallel fuses @30A, maybe series?
    even using 1180 as a RMS value, therefore dividing it by 0.707 then dividing that dividend by 4 ohms, taking the sqrt of the next dividend (28 amps now) even a 125% margin doesn't get you to 60. but if they were in series, that would make more sense.
    Nov 2007
    I have a rockford fosgate p600.1 for a bass amp and i was just looking over how i could make it a little bit safer (ie. make sure it is properly fused in both front and back of vehicle.)
    Just fuse at the front (battery) as that is where the power comes from. No point fusing at the back unless you run a battery in the boot.
    Yes, current draw will be around 60amps when running at peak output.
    No. Never ever replace factory fuses with anything other that what the originals are rated for. Doing so will void your waranty, increase the damage to the amplifier, and create a fire risk.
    I can't be bothered following the power calculations but heres' how I do it.
    Voltage x Amps x Efficiencey (90% class d or 60% class b) = Max continous RMS output (approximation only).
    So with your amp the best case scenario is:
    14.4 volts (car on) x 60 amps x 90% = 777 watts RMS
    This is above the 600 RMS at 2ohm that RF state, so it should meet it's specs.
    Fuses don't blow at exactly their rating. It's normally 2x their rating for instant blow, or 1.x times over a long period of time. Hence how the max peak output can be higher than the max rms.
    Feb 2007
    Kenora, ON, Canada
    Thanks. Definately a different way of looking at it. Using 4ohms as R and 1179W as P, i arrived at 17.17A? Maybe i messed up flipping the equation... I = sqrt(P/R) ?
    hmm..anyway
    Even if they were in series, seems like the first one will still always blow at 30A no matter what is on the other side of it. Parallel would kind of make sense, equation wise though...i dont understand it. Still seems very odd...maybe i'll email rf tech support and get their explanation. Interesting...
    Nov 2007
    Followign on from my edit.
    If they instant blow at 2x amps, then if wired correctly 2x30 amp fuses, one would blow when total current = 90 amps.
    If they used a singe 60 amps fuse, instant blowing wouldn't occur until 120amps of current draw, which is likely to late to pretect the amps electronics.
    Either way what the amp draws isn't overly relevant to fusing the wire from battery to amp. As this fuse is there to protect your car from catchign fire incase your power cables short.
    Fuse to the cable size.
    http://www.the12volt.com/info/recwirsz.asp
    Feb 2007
    Kenora, ON, Canada
    Ahhh thanks Pokki...definately totally left out efficiency in the equation. Performance verification sheet says 65.546%...damn thats not very efficient.
    So...
    P = V*I*(efficiency)
    P = (14.4)(60)(0.6546)
    P = 565.57= 566W RMS.
    According to rap sheet:
    240W RMS @ 4ohms
    393W RMS @ 2ohms
    why such a big discrepancy?
    Nov 2007
    Is the birt cert/rap sheet done at 12 volt?
    So...
    That will be at minimum load. Maybe the amp is happy down to 1ohm.
