I'd use the RF amp.
Wire each sub to 2ohm (voice coils in parallel) and then wire the subs in serries to the amp in bridged mode.
For the MTX with your subs, you only choices are running it at 1ohm or 4ohm. 4ohm will get you 500 rms and 1ohm introduces stability problems unless you mod the amp.
**Edit** Not sure why you're posting here since you got your answer a few days ago here:
http://www.the12volt.com/installbay/...asp~TID~101093
LinkBack URL
About LinkBacks
