Results 1 to 9 of 9
Thread: Amplifier Problem...Need Help
    Jan 2008
    I have an amp hooked up and has power the works. But the subs are not doing anything. I've checked and re-checked all connections...Let me know if you have any ideas on what's wrong. Thanks
    Jan 2008
    Dartmouth, MA
    What kind of cables are you using to connect everything?
    Variable Bitrate rijndael's Avatar
    Apr 2007
    Florida
    have you checked with a multimeter to see if it is actually outputting a signal to your speakers? if not, my guess would be that somehow you blew your subs
    Trouble deciding on car speakers? Clicky Clicky
    My Myspace page (view my pics for carputer worklog...needs updated)
    Speakers: DLS Ultimate Iridium 6.3 Link
    Subwoofer: removed
    Amplifier#1 (Front Stage): DLS Ultimate A4
    Amplifier#2 (Sub) removed
    Jan 2008
    I have RCA cables from the head unit to the amp.
    Jan 2008
    Dartmouth, MA
    is there anything else hooked up to the amp other than the sub? If so is it working? If not, then I would hook something else up to those RCA cables and see if your getting any output. Alternatively you could hook something else up to the amp and see if the sub woofer turns starts working.
    Constant Bitrate jontz's Avatar
    Dec 2007
    Osceola, IN
    Certain head units have the sub RCA outputs turned off by default, you might have to grab the old owners manual and turn them on. I've had it happen before.
    Nov 2007
    you wired the remote turn on to the amp turn on off the deck and not the power antenna, correct?
    Apr 2007
    Florida
    Quote Originally Posted by Mylt1 View Post
    what? could you repeat that?
    Subwoofer: removed
    Jan 2008
    im having a problem with my RCA cables. everything is hooked up and the sub works. but the sub only comes on and works when only one of the rca cables are plugged in. if i plug both in then the protection light or whatever its called on the amp switches from blue to red and the sub doesnt work then when i unplug one of them it works again. does anybody know what might be causing this. if u do plz email me at gabrielkent1@aol.com or on myspace.com/gabekent77721 thx
  1. Lilliput TouchKit problem solved!
    By AAVfReaK in forum LCD/Display
    Last Post: 11-07-2010, 09:29 AM
  2. gps navilock and com problem
    By lele67 in forum GPS
    Last Post: 04-01-2006, 08:41 PM
  3. Problem with directshow filter and WMP
    By EricE in forum Software & Software Development
    Last Post: 03-01-2006, 11:38 AM
  4. Car Idle - power/amp problem?
    By TheFaze in forum Car Audio
    Last Post: 12-16-2005, 12:10 AM
  5. had an all day (9 hr) problem at work....
    By wizardPC in forum Off Topic
    Last Post: 10-20-2005, 12:50 PM
