Oh ok, that's great then, that center/subwoofer is actually 2 channels, just like all the other ones. One "side" is the center, the other "side" is the subwoofer.
Personally, unless you watch movies with 5.1 content, I don't think you really need or want a center channel - because that's juts another thing that you have to fabricate a location for and mount.. unless you are happy with having the speaker lying around in the car.
So I think the most economical way to do this would be to get:
4 channel amp for interior listening
big mono amp for big sub - and I think you should get at least a 12" to give your tailgaters some thump outside
2 channel amp for rear-facing tailgating speakers
The only speakers you would have to buy would be:
1 sub + enclosure
2 rear facing speakers + enclosure
Your 2 rear channels could be connected to the pass-through on your 4 channel amp, and you could put a switch for your remote-power-on wires for the amps, so flipped one way, your interior speakers are on, and flipped the other way, your outside speakers are on - and your sub is always on.
Sorry I keep pushing less channels, but I think you will be really happy with 4.1 sound.. the center channel would be useless for tailgating, unless you actually had 4 tailgating speakers and set them in a circle around the tailgaters... the center channel is really only for playing center channel sound on 5.1 channel media, such as DVDs.
LinkBack URL
About LinkBacks
Even better!
