Page 1 of 4 1234 LastLast
Results 1 to 10 of 31
Thread: 6-channel amp for 7.1?
    FLAC WuNgUn's Avatar
    Sep 2007
    I'm going 7.1 in my car...I was initially thinking two amps (2 channel + 5 channel), but maybe a 6 channel will work?
    The center channel will be powered straight off the soundcard, and the amp will drive the front, side and rear channels...
    Can I then bridge a single 10" sub on, say, the front channel (so I can still have subs while in 4 channel mode)?
    Or will this give me too much power to the front (reducing the Ohms)?
    Jun 2005
    chicago, Illinois
    I would not attempt such an action. Very few amps state in their manual that it is possible and how to perform such an install, but I would highly reccomend against that. Typically a sub requires more power than would be generated by trying to share the channels with interior speakers. And I believe supression or x-over filter/circuit (inclusion of capicators or inductors) would be required to do so. Check with your amp's manual first to see if it is something that stated they reccomend and if they have a diagram.
    PROGRESS:
    Nov 2007
    First of all I would addrsss the issue of why you want 7.1?
    99.5% of movies are still mixed in 5.1 or lower. Most 7.1 mixes you see on DVDs are matrixed mixes , i.e. the addition 2 channels are mathmatically created and do not reflect thr original source. So sticking with a 5.1 setup makes a lot of sense.
    Or if it's to simply fill the car with sound then i'd recomend better quality over greater quantity.
    This seems very odd to me.
    Sounds fine to me.
    Yes, most amps allow for tri-mode operation, you will however have to add suitable caps to your front speakers to act as a high pass filter, and a suiltable inductor on your sub to act as a low pass filter. Alternatively hunt down a phoenix gold xvr crossover which will do all this for you.
    If your amp is tri-mode capable and designed to run down to at least 2ohm stero you should be fine as long as you stick with 4ohm speakers and sub.
    PS you will loose discrete sub signal/control buy not running it of it's own channel.
    Constant Bitrate krnpimpsta's Avatar
    Dec 2007
    DC Metro area
    If you really want 7.1 - and I really don't think you want 7.1. I think you want 5.1.
    Lots of audiophiles actually just have regular stereo (2.1 - TWO CHANNELS), because the extra speakers just add sound interference and reduce the quality of the sound.
    So given that very little content is 7.1 surround, I think you really want 5.1.
    So given that, I think the a more reasonable way to do 7.1 would be:
    1) get a 5 channel amp for your 4 corners + center
    2) get a 2 channel amp for your 2 side speakers
    3) get a 1 channel amp for your subwoofer.
    Then again, I think most 5 channel amps are for 4 channel + sub, in which case you would just get a cheap mono amp for your center channel.
    And then again, not to shoot your idea down, but I think 5.1 is a much better goal sound quality wise and.. just.. practicality wise. Sort of like why Gillette has a 5 blade razor, but they don't make a 10 blade razor. More is not always better..
    _
    Mar 2004
    Little Elm, Texas
    How exactly?
    And I'm going to Echo the question of 7.1....why??
    Why for all of the same reasons mentioned above...???
    Jan Bennett
    Sep 2007
    7.1 because the rear channel is going to be set up also for viewing the drop-down 22" widescreen from the hatch for tailgating
    And for actual 7.1 surround content, well, why not? Sure it won't be used 99.5% of the time, but it's the .5% that matters.
    I'm going with Boston Accoustic Pro60's front and side, and 5 1/4" MBQuart seperates(with passive crossovers) for the rear, so actual 'mode' of the amp is moot I think...
    The Pro60's will be bi-wired thru their crossovers, so everything is covered except the sub...but I don't think it matters if full range goes to the sub. It won't hurt anything, right?
    Amps will be 2 Ohm stables, yes...
    Or I might go with a 2 channel amp for the rear, and a 5 channel for everything else...
    My center channel is a powered Logitech mm28 flat NXT panel speaker...driven out of the Auzen Xplode, there is PLENTY of power for center channel use...why is that strange? What powers your desktop speakers?
    Also, the sub runs from the center channel output from the soundcard, which is typical...
    So maybe a two amp (2 channel/5 channel) would be better suited for my application...
    Sep 2007
    [QUOTE=krnpimpsta;1167989].
    QUOTE]
    Center channel and sub channel are not discreet...they run off the same channel, unless, perhaps it's 5.1 DTS...
    Constant Bitrate Felix509's Avatar
    Feb 2007
    Lafayette, LA
    The Sub Out or the .1 in the 5.1 or 7.1, is also known as the LFE(Low Frequency Effects) Channel.
    It is completely seperate from the center channel and is digitally crossed over somewhere under 100Hz.(my home receiver has 3-4 frequencies to choose from)
    Ours is the age that is proud of machines that think and suspicious of men who try to.
    ___________________________________
    Current SYSTEM
    AMD64X2 2.5
    Xenarc
    ZAPCO DSP-6
    ARCAUDIO SE Amps
    Rainbow Profi CS365 & Profi Vanadium 12"
    Dec 2007
    DC Metro area
    Quote Originally Posted by WuNgUn View Post
    I found that strange because the only time I ever experienced passive speakers (powered by sound card) was when I got a pair for free with my first ISA sound card on my 386 (before PCI cards existed).
    My current speakers? They're logitech branded and powered by a big amplifier in the subwoofer. Even at work, the cheapy freebie speakers are powered by external power.
    The sound card outputs a "line level signal," as in this is basically just the signal - the data. Not enough power to actually create alot of sound, unless you are powering very small speakers or a pair of headphones.
    I don't know what kind of flat panel speaker you have, but I don't know of any audio technology that is capable of creating sound volume that can rival even a crappy stock car audio setup with just a line level signal.
    Sep 2007
    Quote Originally Posted by krnpimpsta View Post
    Read a little closer...I said it's a Logitech mm28, and it's powered...
    And it's capable of holding it's own in the car!
  1. Core Duo / Core 2 Duo Mini-ITX boards
    By RedGTiVR6 in forum General Hardware Discussion
    Last Post: 10-03-2010, 11:30 PM
  2. Front or Rear out to 2 channel amp???
    By FrogDawg in forum Car Audio
    Last Post: 06-30-2005, 03:49 PM
  3. WTB: Decent 4 channel amp
    By tiggs in forum Classified Archive
    Last Post: 02-19-2005, 02:43 PM
  4. Audigy surround 5.1out to 6 channel Amp !! GOOD
    By lookinco in forum Car Audio
    Last Post: 11-25-2004, 03:28 AM
  5. 6 channel amp?
    By auto_robotics in forum Car Audio
    Last Post: 11-24-2004, 02:33 AM
