You could get a cheap headunit with AUX in and hide it behind the dash somewhere...
But i don't see why you can't get a small amp and turn the gain down...
I am installing a carputer on my second car
The thing is I want to sell the car in the next 9 months or so.
I would use onboard soundcard (with line out), and factory speaker (4 speakers)
I talked with the crutchfield guy and he said I would burn my speaker immediately if I use aftermarket amp since aftermarket amp give out a lot of power.
I am not going to buy any aftermarket speaker for this car.
everything that I installed on this car would be removed at the time of sale.
So the least the better.
Any idea?
also, the computer would replace the factory hu, so aux in is not an option
thanks
I prefer not to buy another small headunit. There isn't a lot of space and I don't like the idea of having a hu.
is there anyone running amp with their stock speaker? I've searched the forum and google, there were bunch of opinions.
Some people said it would be fine, another said it would blow the speaker.
Anyone with the stock speaker setup?
btw. this is for an 06 corolla
that crutchfield guy obviously isn't well informed.
the only reason you would 'burn up' your speakers is if you don't properly adjust your gains for clipping. A small (45w x 4) amplifier would be find on a set of stock speakers....again, only if tuned properly.
Jan Bennett
just do a search for multi channel amps and you'll find the specs.
whats your budget?
New System in progress:
M10k
Phaze TD1500 ~> Seas g18rnx/p
Zapco Ref 500.1 ~ 12" tc-9
Transflective Xenarc
My Car Pc Install
My Boat Pc worklog
I am looking for something below $50
I'd like to keep the whole car pc setup below 600 which mean the amplifier shouldn't be more than $50
I've searched multi channel amps on google but couldn't find anything with low wattage rating.
this is what i've found so far
http://www.onlinecarstereo.com/CarAu...roductID=17594
SoundStorm 4F400
400W 4 Channel MOSFET Amplifier
RMS Power Range : 200 Watts
Number Of Channels: 4
Maximum Power: 400 Watts
Low Frequency response: 12 Hz
High Frequency Response: 22000 Hz
Built In Crossovers: Yes
Channel Separation: Yes
would it blow my factory speaker?
or can I go with a 2 channel amplifier?
something like this
http://www.onlinecarstereo.com/CarAu...roductID=17601
i'd probably mod two sonic impact t-amps 15wrms per chan. and small when taken out of the case.
M10k
My Car Pc Install
My Boat Pc worklog
I was going to suggest that as well - they're also handy amps to have lying around.
