Results 1 to 4 of 4
Thread: headunit help please
    Jan 2008
    upper darby pa
    1994 Nissan altima - can someone please help me with the wiring for my head unit i got a diagram from website and hooked all the wires up but still no power my antenna goes up thats about it
    Elsewhere
    Either the headunit is faulty or the wiring is wrong.
    I highly suggest getting a wiring harness for your specific make/model vehicle. It makes the installation process a lot easier.
    Now understand....
    This forum is dedicated to CarPCs and installing them in your car.
    The car audio forum is dedicated to integrating your car audio system with your CarPC.
    For specific questions related to car audio equipment systems that do not include CarPCs, I would recomend checking out car audio specific forums:
    http://www.elitecaraudio.com
    http://www.carsound.com
    http://www.caraudioforum.com
    http://forum.sounddomain.com
    http://www.realcaraudio.com
    http://www.carstereo.com
    http://www.caraudiomag.com
    http://www.termpro.com
    http://www.the12volt.com
    http://www.talkaudio.co.uk
    http://www.caraudiosecurity.com
    et. al.
    There is a chance that someone on here might have an answer for you, I would just hate for you to wait around for it when I know you could get an answer much quicker on a dedicated forum.
    Good luck.
    How about the Wiki?
    Low Bitrate stroths's Avatar
    Jan 2008
    Dallas, Texas
    Also make sure you purchased a wiring harness for your car which should have the wires labeled. You can pick one up at Best Buy, Circuit City or maybe cheaper at Wal-Mart.
    Definitely check out the forums DarquePervert pointed out though.
    Jan 2008
    upper darby pa
    thanks
  1. stock headunit + aftermarket amp possible?
    By theheel in forum Car Audio
    Last Post: 09-11-2006, 03:12 AM
  2. Headunit or not to headunit EPIA 13000
    By Philhop in forum Car Audio
    Last Post: 06-09-2006, 07:45 AM
  3. Do I need a soundcard if I'm using a headunit?
    By rudeboymcc in forum General Hardware Discussion
    Last Post: 04-14-2006, 04:14 PM
  4. Replies: 1
    Last Post: 04-04-2006, 04:00 PM
  5. radio receipt headunit
    By Tijs67 in forum Car Audio
    Last Post: 07-22-2005, 08:05 AM
