Results 1 to 6 of 6
Thread: Use Factory Speaker Wiring?
    Constant Bitrate utd09bry's Avatar
    Sep 2007
    Dallas,TX
    Quick One:
    Anyone know/see a real difference in using factory speaker wiring versus running your own cable?
    I am looking at finally adding an amp so I can get rid of my HU. Amp is only about 100w RMS x2.
    Any thoughts?
    Elsewhere
    Factory cable is higher gage (thinner), making it able to carry a smaller load.
    With the amp you're looking at, factory wiring should be acceptable, but you'll get better sound quality if you run your own speaker wire.
    How about the Wiki?
    Sep 2007
    Dallas,TX
    I would love to avoid having to run that wiring. I will probably end up doing it though...
    thekl0wn's Avatar
    Apr 2005
    PoCo, Indiana
    To be done correctly, IMO, it needs to be replaced... BUT, yes the OEM wiring will suffice.
    Play with it, 'til it's broke.
    Ge0
    Ge0 is offline
    Nov 2007
    Metro Detroit
    I have a tad bit of experince in the subject.
    What is the application, to drive door speakers or a sub?
    Door speaker:
    One has to ask themselves, are you going to continuously push that 100W amp to its limits? Pushing a typical door speaker to 100db (that REAL loud for a door speaker) can be done with approximately 32W. Driven into a 4 ohm load that is 2.8A. Chances are your vehicles speakers are wired with a minimum of 20ga cable, probably 18ga.
    Even if you had 20ga cable. The resistance of said cable is approx 0.08ohm per foot. Power loss across a cable run of 12ft would be 7.5W. Not trivial, but, not terrible. things improve with 18ga cable. It's resistance is 0.06ohm per foot. Power loss along the same wire run is 5.6W. Now, lets put things into perspective. Say you had the ambition to rewire your system with 16ga cable. This cable has a resistance of 0.04 ohm per foot. Power loss down a 12ft cable would be 3.8W.
    There will be no appreciable power loss across the stock cable. The difference between 20ga and 16ga cable may gain you 0.5dB or so in additional output. Your ears aren't that sensitive. Therefore, keep it. Statements suggesting you'll get better SQ are silly. The cable adds no distortion or frequenct response anomalies to the signal. The only difference being where there is a grosse undersizing of cable. Where attenuations of 3dB to 6db are encountered. The human brain seems to equate louder to sounding better since your brains sensitivity to various frequencies starts to flatten out as volume increases. Music sounds more natural.
    Subs:
    Make sure you use at least 18ga cable to prevent excessive power loss. Subs are much less efficient than door speakers and require more current to get them going. You need to achieve higher sound pressure levels with a sub to make it sound as loud as door speakers. This is because your ears are less sensitive to low frequencies. You may need 120db out of a sub to make it sound as loud as 100db from a door speaker.
    I hope my mindless drivel has helped you decide.
    Ge0
    Sep 2007
    Dallas,TX
    I am driving some Pioneer 3-way door speakers... nothing too crazy. I actually tested one of the speakers with this amp by splicing into the factory harness... and it sounded fine. Hard to tell with only one speaker going, but I think it will work out.
    And yeah I should have done the math in the first place. Ohm's law is <3
    Thanks for such a good write up!
  1. Wiring an amp in a car with factory deck.
    By tbird2340 in forum Car Audio
    Last Post: 03-06-2007, 02:10 AM
  2. Utilize factory subwoofer and speaker amps
    By miwise in forum Car Audio
    Last Post: 01-13-2007, 01:29 PM
  3. STi Speaker Wiring Setup?
    By i_drank_what in forum Car Audio
    Last Post: 09-01-2005, 12:10 PM
  4. sound system wiring advice and componant choices for a newbie
    By dbzeag in forum General Hardware Discussion
    Last Post: 08-27-2004, 07:44 AM
  5. car audio wiring harness -> computer speaker port ??
    By nadir_s in forum General MP3Car Discussion
    Last Post: 01-07-2004, 10:48 PM
