there is a little circuit inside the db9 connector. Check out his website. It shows it.
Im still conceptualizing my install. I plan on using a laptop that has a free serial port. I have read about the MJS Gadgets device, but if its really a simple FTDI USB/serial adapter, then couldnt I just connect the SC-C1 tuner to my laptops serial port?
My laptop only has 2 USB ports, so if I can have ANY component use the serial port, that would be great so as to still have 2 free USB ports for other things.
What say? Could I just hack together a connector head and solder the wires to a DB-9 head?
OK I see that he has already built an RS232 version. This is what I want, especially since using optical out is supported.
but they are discontinued, and now out of stock!
Is it possible to get an optical out of the USB version?
Thanks!
I would recommend sending Mitch an email at mitchjs@rush2112.net.
He'll be able to answer your questions about his hardware.
