- you can't go direct fom pc to speakers, you need an amp in between.
- you can choose to have it play though the front stero speakers, be distributed to all speakers, or be surround processed to all speakers
Depends what you want.so is a 5.1 setup the best ?
Run the speaker wire down one side of the car and the power down the other is an easy solution.Also say I have two amps in the trunk one for the front and back speakers and the other for the sub(s) then I have to run speaker wire right next to the power wire that is going to the trunk or no, is there a way to avoid that.
LinkBack URL
About LinkBacks
