Page 1 of 4 1234 LastLast
Results 1 to 10 of 31
Thread: Speaker wire: stranded vs. solid?
    FLAC Nola111's Avatar
    Jan 2007
    New Orleans, LA
    Is there any difference in sound quality, or advantages/disadvantages to using solid wire vs. stranded for speaker cable?
    Maximum Bitrate FusionFanatic's Avatar
    May 2007
    Boston
    Quote Originally Posted by Nola111 View Post
    Is there any difference in sound quality ~ to using solid wire vs. stranded for speaker cable?
    some say yes, some say no. most would agree that the difference is not significant enough to worry about. I seriously doubt you could hear any difference in a car.
    advantages/disadvantages?
    solid wire is cheaper to buy and can be bent to shape, but it's not very flexible and can fatigue (or break) quickly if it's moved often. solid wire offers less resistance for DC current.
    stranded wire is flexible, easier to work with, and is much more durable, but it's also more expensive. stranded wire offers less resistance for AC current.
    Jan 2007
    New Orleans, LA
    Ah ha. Thanks for the info CG!
    Dec 2007
    Boulder, CO
    I believe solid core wire has more resistance...? Electrons flow over the surface of the wire (as opposed to flowing through the wire like most ppl think) so more electrons can flow with stranded wire because there is more surface area. Will you hear the difference in your application, idk...
    _
    Mar 2004
    Little Elm, Texas
    Quote Originally Posted by ComputerGeek View Post
    It depends on the ear we're talking about here.
    All true!
    I should note that smaller wire is better got high range frequencies while thicker is better for lower range.
    Part of this is due to the way in which electrons travel down the wire.
    Since higher frequencies travel at a faster pace than lower frequencies, you want to slow them down some so that the timing is consistent between frequencies.
    This is why we have 3 different kids of speaker wire in our car. One for tweets, one for the 3"s and the same for the 5" subs and the 16" sub.
    Yes, this is extreme for some. Will you notice a difference? It totally depends on your ear and your level of appreciation for the minute differences in audio.
    For the average user on this forum, your average stranded speaker wire would be the best bet in the car.
    Jan Bennett
    MySQL Error scott_fx's Avatar
    Dec 2004
    Los Angeles Ca
    you could always just use a solid bar:
    New System in progress:
    M10k
    Phaze TD1500 ~> Seas g18rnx/p
    Zapco Ref 500.1 ~ 12" tc-9
    Transflective Xenarc
    My Car Pc Install
    My Boat Pc worklog
    Maximum Bitrate Megalomaniac's Avatar
    Jan 2006
    The Colony, TX
    Quote Originally Posted by scott_fx View Post
    I thought that was just tubing?
    There is a guy I saw at show who runs JBL, I believe he competes in IASCA iirc.
    He did copper to for his subs. I dont know if you can see it but its there.
    screen name here use to be MegaloRESE15"
    _
    Mar 2004
    Little Elm, Texas
    heh - he's not competing any more. He did ONLY SQ, NO install. Mostly USACi shows.
    His name is Vince and he recently moved from Fort Worth to Kansas City.
    It's not solid, it's wire run inside a tube then bent.
    Jan Bennett
    FLAC WuNgUn's Avatar
    Sep 2007
    I think the stranded vs. solid comes down to enviromental conditions when talking about auto installs...among other things.
    Stranded has a tendancies to oxidize easier than solid...
    However, insulating material, and layout has just as much to do with sound quality as does the wire itself!
    Having your wire resting on plastic or non-wool material is detrimental...
    Never use speaker cables shorter than 8'...and try to keep interconnects short as possible...
    If you can manage it, use bare, solid copper wire from any passive crossover to speaker. Try to keep the bass and treble wires at least 1ft. apart. Don't bundle the wire runs from the amp to the crossovers...
    Never bundle wires! If you must run wires parallel for more than a foot, separate them by 6" or more. Wires that cross at at 45 degrees or more can touch without any sonic degradation.
    Seperate your 2 channel RCA interconnects by several inches if possible...
    If you have a "clean" power setup, you might also try removing the plastic insulation from the interconnect, revealing the braided sheathing underneath.
    Open air has the best dielectric properties. Teflon comes very close.
    And lastly, Google VenHaus speaker wire...
    Jun 2005
    Here is another approach:
    Probably overkill for audio; where I work we use it for big power.
  1. Speaker wire to ground amps etc?
    By geeky_hawkes in forum Car Audio
    Last Post: 10-08-2006, 06:16 PM
  2. FAQ: How to Wire an OPUS PSU
    By Quattro in forum The FAQ Emporium
    Last Post: 08-26-2006, 01:38 PM
  3. Stranded wire vs. solid
    By Eternalodyssey in forum Power Supplies
    Last Post: 11-15-2005, 07:41 PM
  4. recomend me an AMP. stock speakers, no subs.
    By mattress in forum Car Audio
    Last Post: 02-05-2005, 02:18 AM
  5. Replies: 37
    Last Post: 05-17-2004, 08:01 PM
