Page 1 of 3 123 LastLast
Results 1 to 10 of 26
Thread: unable to play USB HDD 40 GB
    Feb 2008
    Hi folks..bought a Chinese made head unit for car with DVD/MP3/GPS/etc..etc...hoping to play all my mp3 from a 40GB USB HDD. It can play mp3 off a 128 flash drive...but not from a 2 GB flash drive and ofcourse not from my 40GB USB HDD. Have you guys got suggestion. Im sorry if this has been dealth with before, Im new here.
    Maximum Bitrate Woofnstuff's Avatar
    Oct 2007
    Auckland
    common things to check.
    formatting of the drive, some only like "fat32"
    no more than 99 songs in a directory
    does the hard drive spin up or does it sit there making "ticking" noises. if its ticking its not getting enough power via usb.
    check the manual and make sure there is no maximum limit to the size of the drive that it can read from. it might only be able to see up to 1GB for example.
    if you brought it from a shop, take your drive into the shop and try it on a unit there.
    if it still dosnt work in the shop, get a refund or swap it for one that does work with yoru hard drive? additionally if you asked the sales person for one that you can plug your hard drive into and they said this one should, you should not have any problems swapping it. as they mislead you
    Feb 2008
    Thanks very much for your reply, I have checked these things already. It accepts 128 meg FAT32 flash drive..but fails with 40 GB FAT32. There is no ticking sound but the light on the HDD case is dim which makes me think it needs power. From memory I know most OS support 32GB as FAT32. So i have to partition to 30 GB or something. And there's no way I can ask for a refund as I bought it off eBay and the guy doesnt reply to the email. Also the manual is probably written by some Chinese/Japanese. I have to decipher the meaning of their english.
    Oct 2007
    Auckland
    another thought is if you know someone with an ipod, see if it can read that.
    Feb 2008
    Thanks again....i hv checked with HDD partitioned 29GB FAT32....no luck. still looking.....
    Oct 2006
    try checking the tree. sony headunits supports only up to 3 subfolders and 399 files i guess
    Elsewhere
    Most headunits have a limit to the amount of storage they can access.
    Most will not read from a USB hard drive.
    I'd expect that a generic low-budget Chinese knock-off unit like yours would not be able to.
    How about the Wiki?
    Car Audio Moderator durwood's Avatar
    Sep 2006
    Chicagoland (St. Charles,IL)
    USB standard is current limited to 500ma on the 5V line. If you are using a laptop drive that gets all power from 5V and the current rating is >500ma (which it usually is) than you need an external 5V power supply to give it more current (amps).
    If it's a full size desktop drive, it will definitelly need an external power supply because the 12V and 5V draws too much current.
    If you rectify the power issue, and it's formated to FAT32 and have not exceeded the file/folder limitations set forth by the mfg, then I would say it's a matter of a cheap chinese headunit.
    Feb 2008
    I have been researching this situation as well.... I am going to be purchasing one of the new AVN systems with USB ports as soon as I compare them all. The new ones from the CES08 in January should be reviewed within the next few months. In the meantime, my research has led me to the following links:
    http://www.techsupportforum.com/hard...-work-car.html
    http://www.ridgecrop.demon.co.uk/ind...at32format.htm
    I hope this helps... it seems that Microsoft Sync allows for this quite easily...
    Michael
    Newbie defgr's Avatar
    Feb 2008
    Athens, Hellas
    ...Problem solved!
    Dear sir,
    First, you have to format your IDE 2.5" HDD to FAT32 format. Do not use partition magic or anything else. Make sure that you use a 40Gb hard disc. Larger capacity consumes more power (W).
    Formating in fat32 gives you a max capacity of 29Gb. Use the rest as file storage, or what ever you like. Car audio will not see any other partition, any way.
    Now, Buy one case with voltage input (prefer one with the normal size USB female input plug).
    One of those which are allso media players, are fine too.
    Get from Radiosack a 4 cell battery case (comes free with the media player case mentioned above) with the appropriate plug and polarity according your HDD case.
    When you gather all that gear, then you are ready to go!
    Now!
    You have and have done all the above (formating, battery case, ect...).
    You are in your car.
    Start the car! (if you start it later, probably the power will cut off and this is dangerous for the hard disc).
    Your car stereo is off!
    You have in hand your hard disc and the battery case.
    Plug first the USB cable, to the hard disc.
    Then plug the other end to your car stereo.
    AT THE SAME TIME PLUG THE BATTERY TO YOUR HDD CASE FOR A FEW SECONDS.
    It would be helpfull if the battery case have a switch.
    Just a few seconds will do the trick!
    HDD needs a kickstart current to get going.
    After that, it will not shut down, unless you switch off the car stereo.
    Changing source, will not affect the status of the hard disc. Switching back to USB input, the hard disc will resume without the use of the external power.
    This procedure is needed only once, every time you attach the HDD to the car stereo for the first time in a day. If you leave the HDD attached to the car stereo, kickstart current is not needed.
    Please note that the car stereo MUST have a normal size USB female input plug.
    I hope that this will help you.
    defgr
  1. USB hdd fast enoug ??
    By DJKOK in forum General Hardware Discussion
    Last Post: 03-08-2008, 11:08 PM
