Results 1 to 6 of 6
Thread: Loud Beep whenever button is pushed
    Feb 2008
    I have a Sony head unit in an older Miata which emits a very loud and very annoying single beep sound any time one of the function buttons (volume, mode, etc.) is pressed. I tried the reset but that didn't help. Any suggestions?
    Variable Bitrate brucedog's Avatar
    Oct 2007
    Philadelphia, PA
    Don't push the buttons....
    Dunno, maybe you have the volume up loud and when you press buttons the sound is just appropriate for volume level?
    Sounds like the unit is just built that way, but try taking the fuse out and leaving it for a minute. Then at least you'll be starting fresh.
    maybe if you give model no. someone else has had experience w/ this.
    happy carpc'ing!
    Elsewhere
    Maybe if you read the manual for this unit, there would be a solution for turning the annoying beep on or off.
    How about the Wiki?
    Oct 2007
    Philadelphia, PA
    RTFM?
    What a concept!!??!!
    Feb 2008
    In most head units that have the beep function in them there is an option somewhere in the menus to turn this function on or of. You may have to doe some searching. I have seen them buried in weird places in the menus on decks
    Sep 2006
    Cornwall, England
    I had an old sony head unit with the high pitch anoying beep. I eventually got it to stop by holding the 'function' button and pressing '6'
    If the 'function' button doesn't work, or you havn't got one, try the 'shift' or 'mode' or 'sel' button.
    Sorry I can't remember exactly
    ViVE - Volkswagen In Van Entertainment:
    VoomPC 2, VIA C7 2GHz
    7" Lilliput
    120Gb Sata drive
    1GB RAM
    [||||||||||] 100% - Planning
    [||||||||||] 100% - Software coding
    [||||||||||] 100% - Built
    (Always tweaking!)
  1. iGuidance Hacks
    By pbarrette in forum GPS
    Last Post: 12-28-2007, 03:06 PM
  2. Trying to hack my laptop power button
    By Stevo759 in forum Laptops, Netbooks, Tablets, UMPCs, etc.
    Last Post: 12-14-2005, 09:29 PM
  3. Can a hovering button be implemented ?
    By tolisn in forum Road Runner
    Last Post: 10-15-2005, 11:11 AM
  4. button repeating bug?
    By scott_fx in forum Centrafuse
    Last Post: 02-23-2005, 11:35 PM
