Results 1 to 5 of 5
Thread: Removing 1998 Altima Original Radio/CD
    Feb 2008
    Hello. I am replacing the original Radio/CD in our '98 Altima GLE with a new unit of the same type. How do I remove the original unit? For example How do I remove the face plate and get access to the screws that hold the unit in place.
    Regards,
    Terry
    Maximum Bitrate boomintrac's Avatar
    Apr 2005
    2hr west of Chicago
    to remove the faceplate on a factory unit Id use a hammer
    New Ipad
    Zapco DSP-6SL
    Zapco Reference 360.4: H-Audio Soul, x2 right side
    Zapco Reference 360.4: H-Audio Soul, x2 left side
    Zapco Reference 500.1: JL Audio 10W3V3 Stealth box
    Low Bitrate stroths's Avatar
    Jan 2008
    Dallas, Texas
    Check one of the car audio forums and you might find instructions for your model. Otherwise, you will have to either buy instructions online or take your chances with a hammer.
    Jul 2001
    Pull the ash tray out and there will be a screw behind that, remove the screw and pull the panel. Then there's some screws for the bottom of the bezel, 2 I think. Then you've gotta pry out the air vents at the top of the dash. There's 2 more screws and the whole bezel should pull off. Then it's either 4 or 6 screws that hole a huge chunk of electronics in.
    Feb 2008
    Thank you Shadow. Much appreciated.
    T.
  1. Indexing music in 1.0.9.8 Failed
    Last Post: 07-07-2007, 12:19 PM
  2. 1998 Altima Carputer project
    By silveralt in forum General Hardware Discussion
    Last Post: 12-25-2005, 03:23 PM
