Results 11 to 20 of 27
Thread: lines on screen due to subs?
  1. #11
    May 2006
    Lima, Oh
    No there is no noise in my system whatsoever, it sounds great!
    My screen is grounded though my old stereo power wires, so im assuming chassis ground.
    Carputer runing Media Engine
    kicker mids and highs, on a eclipse amp
    10" lightning audio subs on a kicker, soon to be replaced with MA audio comp subs!
  2. #12
    Maximum Bitrate Woofnstuff's Avatar
    Oct 2007
    Auckland
    the screen may be getting an earth thru the video cable shield wire.
    try running a new earth wire for the screen, try an earth point close to it first since that easier, then if that still dosnt work run a wire to the earth input terminal on the amp.
    since that may be easier to get to in theory than your normal earth point and for testing it should suffice.
    of course you could just get a power noise suppressor/filter and put it on the screen.
    those small black boxes you often get on car stereo's power wires.
    if that dosnt work you could try putting a ground lift box on your RCA cables to the amp
    http://www.radioshack.com/search/ind...0isolator&sr=1
  3. #13
    FLAC greatwhite's Avatar
    May 2007
    Top o' the world Ma!
    I had a similar issue when I was running my system in "beta" mode. I'm willing to bet your 10 guage power wire is too small to power all your components.
    I had a 4 gauge power wire, but while I was testing and setting up the system, I quickly wired the sytem with some 12 gauge from the splitter block.
    The result?
    My screen would flicker anytime to music was turned up past approx 5%.
    When I permanently wired it with 8 guage the problem went away. 12 guage was "starving" the puter for current and the video card was having difficultly keeping up. Keep in mind, my system was mostly 4 guage except for a few 2 foot 12 guage runs from the splitter block to the amps and the 'puter. You're running 10 guage all the way from the battery if I read your post correctly.
    I'm not saying that's your problem, but if you're powering everything off a 10 gauge that's around 20-25 feet long.................
    Well.......................
    Also, what guage is your ground wire? It should be at least equal to the size of your power supply wire.
    Leonardo Da Vinci
  4. #14
    May 2006
    Lima, Oh
    OMG I just thought of something! I decided to save money and run a few things through one cat 5 cable. Cat 5 is unshielded. My composite to the screen runs through that cable. That may be it, what do you guys think?
  5. #15
    May 2007
    A few things?
    What few things are we talking about here?
    Leonardo Da Vinci
  6. #16
    May 2006
    Lima, Oh
    well as mentioned my composite video for the screen, a no longer used audio rca, and the power switch for my pc.
  7. #17
    May 2007
    I'm still betting on a power issue.
    S-video?
    Are you running a TFT screen or a lower res screen?
    Leonardo Da Vinci
  8. #18
    May 2006
    Lima, Oh
    Yah actualy I am runing a TFT. I wasn't loaded with cash at the time, bc I just bought the car I put it in. It kinda scared me, but it actusly is very fast and has a descent picture for a TFT. I can read internet pages on it.
  9. #19
    May 2007
    Did the screen come with a vga cable?
    Does it even have a vga in?
    I'd use that if possible instead of a home made s-video cable.
    That could likely be your problem right there..........
    Or am I not understanding your post correctly?
    Leonardo Da Vinci
  10. #20
    May 2006
    Lima, Oh
    nope white you got it right. There is no vga in. Its just a manuel single din in dash unit with two video in's and an audio in.
  1. FAQ: VGA vs. Composite (Video) Screens
    By cproaudio in forum The FAQ Emporium
    Last Post: 12-28-2007, 11:45 AM
  2. Replies: 34
    Last Post: 11-06-2007, 02:42 PM
  3. Tedelex LCD Screen
    By ryanbyn01 in forum LCD/Display
    Last Post: 09-05-2007, 08:46 PM
  4. my poor screen
    By jay_tu in forum LCD/Display
    Last Post: 08-11-2006, 03:19 PM
  5. Screen intereference - Subwoofer/bass related
    By Pabs in forum Power Supplies
    Last Post: 10-18-2005, 03:25 AM
