Results 1 to 6 of 6
Thread: would this work?
    May 2007
    would this work?
    hi,
    have had a casputer system for some time now, but my lcd touchscreen started to flicker and smell burned one day, so i ame going to change it.
    Now im thinking of buying a indash touchscreen with a DVD player, so i wonder if i can use 2 audio soruces. What will happen i i connect it like this? will in shortcircut?
    Variable Bitrate walstib's Avatar
    Jul 2005
    Atlanta, GA
    Why not run the CD player to the audio input of the PC?
    Carputer Project Status:
    0% - Mobo died on 2/17/08
    Check out the worklog for my '01 Pathfinder.
    MySQL Error scott_fx's Avatar
    Dec 2004
    Los Angeles Ca
    bad things could happen, you would need a 'mixer' or switcher if you wanted to hook it up like that.
    mixer if you wanted to have two audio sources at once playing through the amp (for instance gps from the computer and music from the head unit)
    switcher if you wanted to play either one or the other, but you could just use the aux input in the head unit if you were going to hook it up that way
    New System in progress:
    M10k
    Phaze TD1500 ~> Seas g18rnx/p
    Zapco Ref 500.1 ~ 12" tc-9
    Transflective Xenarc
    My Car Pc Install
    My Boat Pc worklog
    Maximum Bitrate Woofnstuff's Avatar
    Oct 2007
    Auckland
    while it might work, if both were powered on at the same time it might not, you would also be glared at by the people who do it right society.
    does your cd player have its own volume control?
    how did you adjust the volume previously?
    one option is to invest in a small mixer or something that has several inputs and a volume to the amp.
    as said above using the input of the carpc might be the easiest way.
    only issues i see with that is a potential small delay while the signal is processed thru the computer. so dvd's might look slightly out of sync.
    Dec 2004
    Los Angeles Ca
    M10k
    My Car Pc Install
    My Boat Pc worklog
    May 2007
    cant figure out how i did not think of using the Line-in on my soundcard hehe
    thanx guys
  1. How to make Winamp TV Plugin work with RR
    By ramez75 in forum Road Runner
    Last Post: 09-03-2010, 12:17 AM
  2. Stealthy surfing at work?
    By e_z_street in forum Off Topic
    Last Post: 10-07-2009, 02:30 AM
  3. Quality of work
    By BMVEE in forum RR Skins
    Last Post: 03-14-2007, 08:38 AM
  4. Prison vs Work
    By ACHIEVER in forum Off Topic
    Last Post: 04-15-2005, 01:53 PM
  5. Replies: 4
    Last Post: 11-18-2002, 08:59 PM
