Results 1 to 3 of 3
Thread: start-up pop and crackling
    Feb 2008
    when i turn the key in my car and the amplifier gets power, it makes a very loud POP sound. also, when i listen very closely to the music, i can hear a slight crackling, not a steady crackling either, but sporadically. what is causing these?
    Mar 2004
    Little Elm, Texas
    this thread should not have been posted in the high end forum....why it was I don't know...
    as for your system....the only real reason for turn-on thump (non-carPC related) is a cheap amplifier.
    Unplug the RCAs at the amplifier then turn the system on/off a few times. If you still have the noise, then it's the amplifier. If not, plug the RCAs back in, turn the gains down, and turn the system on/off a few times, if it goes away, then you have your gains set too high.
    The crackling you've been hearing could also be blown speakers...cause by a crappy amp or improper tuning (turning the gain controls all the way up unjustly so).
    Jan Bennett
    FLAC greatwhite's Avatar
    May 2007
    Top o' the world Ma!
    Do you have the amp remote hooked up to acc power or a remote turn on lead?
    Leonardo Da Vinci
