Results 1 to 10 of 12
Thread: I am having problem with stock accord 08 Subwoofer
    Feb 2008
    Hi guys
    I am new here please don't disappoint me !!
    I just boght new Honda Accord 2008 V6
    wich comes from factory with huge woofer !!
    but in the setting I put
    Bass +6
    Tre +6
    SubWF +6
    Fad =C
    Bal =C
    Kiss Kiss T-Pain feat. C.Brown
    but all what I get noise and sound of vibration !!
    also I knew that when I press by my hand all the noise GONE !!
    What should I do ??
    Variable Bitrate brucedog's Avatar
    Oct 2007
    Philadelphia, PA
    Seems like if you feel certain that sub is problem child, you should go back to the dealer of your new car....
    Do you have experience with subs? They CAN sound kinda fuzzy and buzzy 'till one gets used to 'em.
    This is a Car PC forum where we generally discuss connecting our carpc's to lots of things, including our car sound systems.
    Best of luck.
    Oct 2006
    I've a similar set-up in my 2007 Ridgeline. Of course, the sub is different sized. First, bear in mind that this is an OEM speaker. You may want to address that all the way around. My Honda has Pioneer speakers, but they're pretty marginal. You may want to check mounting bolts for the subwoofer, too, but I don't think that's your problem.
    Then, try easing back on all the settings. You're maxxing everything out & that's pretty much guaranteed to distort. You didn't say what volume you were running -- probably you're up around 30. I've found that unless the source material (CD or whatever) is relatively recent, running SUB, BASS & TREB at +2 or +3 & volume around 24 (on the Honda 40-point scale) is usually sufficient.
    But if you want profound bass, you're going to need to upgrade the speakers all around & maybe look in to more amp.
    Feb 2008
    No It is happing even when the volume is from 12 to 40
    & I have checked all the bolts all tight
    and the CD is Original not a copy tested on Mitsubishi Lancer EX and works perfectly
    Variable Bitrate Bimmerstyle's Avatar
    Sep 2006
    It's an OEM subwoofer. It simply won't do the things you expect it to do. With all the settings to +6 it will just sound horrible. Altough the guy in the movie seems pretty impressed by it.
    You seriously need to upgrade your system if you want the bass to be that loud. Stock speakers are never designed to play that much bass, even if they have a sub.
    A side note. This actually is a forum about putting PC's in your car. The Audio section of the forum is created to solve audio problems when using a Car-PC. In most cases we refer people with dedicated car-audio problems to dedicated car-audio forums because knowledge of these things is probably better over there but in your case you probably will get the same answer everywhere.
    BMW 525tds -Biostar I94GM-I4 -Celeron M44O 1,86GHz, M2-ATX, 1Gb, 320GB -HQCT RDS tuner -Creative Extigy -iBus controller -Lilliput 7" touchscreen -DLS Ultimate A7 amplifier -Focal 130K, 130V, 27V2 speakers
    Bezel Worklog-My Install -iDrive F01 RR Skin
    Maximum Bitrate boomintrac's Avatar
    Apr 2005
    2hr west of Chicago
    DAMN I could have had sound like that!!! and to think I spent all that money on audio.
    New Ipad
    Zapco DSP-6SL
    Zapco Reference 360.4: H-Audio Soul, x2 right side
    Zapco Reference 360.4: H-Audio Soul, x2 left side
    Zapco Reference 500.1: JL Audio 10W3V3 Stealth box
    Jun 2005
    chicago, Illinois
    I would simply suggest that you put dynamat under that rear panel. The plastic panel is probably vibrating against the metal.
    Mar 2008
    2008 Accord Sub Woofer
    I too am having problems with my 2008 Accord sub woofer. Its nice to know (in a strange sort of way), that others have the same problem too. The woofer actually sounds like its blown. But, the problems appears to be intermitant. One thing that I noticed is that when I'm listening to talk radio I dont hear it as much as when I listen to music. Took it to the dealer and of course, they couldn't find the cause of the problem. Will be taking it back again as, the problem seems to be getting worse.
    Nov 2007
    A majority of Hondas use a lot of plastic parts, especially the rear deck.
    My 2004 Honda Accord LX coupe doesnt have a stock subwoofer and rattles are apparent.
    My volume is never maxed out and I can only with stand the quality of the sound at half way. Even at lower volumes the bass sounds distorted and the trebles on the tweeters are very harsh which causes immediate listening fatigue.
    With my new settings at -2 treble, -1 bass it is alright for now. Will eventually put a set of components in soon! =)
    Like what others have said, the solution would be finding where the rattles are coming from and reinforcing those areas by either tightening the screws, sound deadening mat, expanding foam or just simply insert pieces of cushioning foam to stop it from vibrating.
    There isn't much low frequencies in talk radio thus it is not affecting the subwoofer.
    What are your settings like? It sounds like your bass might be set too high and it is distorting the subwoofer.
    Aug 2009
    If you want bass in that car with stock audio system, just unplug the two rear speakers, they only rattle and distord, let the front component alone with the sub and the sound will be way better. Drop the treble a bit or if you can install two-ways crossovers and bass blocker for front it will be even nicer. The stock sub is not so bad, don't expect to beat a 1000W after market but you can get pretty good bass with it with a proper setup.
  1. dual vioce coil sub/amp wiring
    By hotponyshoes in forum Car Audio
    Last Post: 12-24-2007, 01:20 AM
  2. Not your typical flicker problem
    By JPuma in forum LCD/Display
    Last Post: 05-30-2007, 10:28 AM
  3. subwoofer grounding problem
    By megagoo in forum General Hardware Discussion
    Last Post: 12-24-2005, 12:41 AM
  4. had an all day (9 hr) problem at work....
    By wizardPC in forum Off Topic
    Last Post: 10-20-2005, 12:50 PM
  5. audio problem
    By tiburonputer in forum General Hardware Discussion
    Last Post: 08-11-2005, 04:58 PM
