Results 1 to 8 of 8
Thread: Problem relocating amp and subs
    Feb 2008
    I recently upgraded my system and gave away my old p2002 RF amp and 10" alpine subs to my neighbor. They worked great in my car. In his it is hardly getting any power to the 10" subs at all. The subs are good (I just pulled them out of my car) but sound is extremely weak in his car. Only thing I can think of is either his head unit has issues or the rca's are bad. I checked and ground and power supplies are good
    Maximum Bitrate crooper's Avatar
    Nov 2006
    Everett, WA
    Might need to re-adjust the input gain since you have different head units. Also, what sounds great in one car may not sound as good in another. Maybe he has the speakers in a bad location.
    Constant Bitrate krnpimpsta's Avatar
    Dec 2007
    DC Metro area
    Either gain, or I would double check ground. While the amp & subs are on and playing music, use a voltmeter to see the voltage between the 12V and GND ports on your amp. If it's not 13V+, then then your ground is not good enough.
    Feb 2008
    What I mean by weaker is I can barely hear the subs. The gain is set at about 3/4 and there isn't much of a difference. He put a meter on the ground and it was fine
    Maximum Bitrate boomintrac's Avatar
    Apr 2005
    2hr west of Chicago
    what kind of car was the stuff in and what kind of car did the stuff get put in, could also check phase.
    Aron
    New Ipad
    Zapco DSP-6SL
    Zapco Reference 360.4: H-Audio Soul, x2 right side
    Zapco Reference 360.4: H-Audio Soul, x2 left side
    Zapco Reference 500.1: JL Audio 10W3V3 Stealth box
    Dec 2007
    DC Metro area
    Quote Originally Posted by perrottela View Post
    What I mean is, you can have a bad ground while still having a connection from the battery. Just because you see 12V when nothing is running does not mean it's a good ground.
    A bad ground will have resistance that will only show itself by lowering your amp's input voltage when current is passing through it b/c of Ohm's law (V=IR).
    A bad ground will look perfectly fine on a meter if your system is not running. Have you tried testing the voltage between +12V and GND while the system is running and playing music?
    Maximum Bitrate Woofnstuff's Avatar
    Oct 2007
    Auckland
    whats feeding the amps, direct from the head unit? front, or back or sub output?
    assuming there is no bass cut feature turned on on the head deck.
    Newbie BasslineMilitia's Avatar
    Feb 2008
    New Zealand
    aye.. am i reading this correctly...? running subs directly from the head deck??
    and phase isnt really an issue, sure it will sound different but if you hooked teh speaker up out of phase you'll still get output.
    check your leads. When people take gear out of our shop to use they give us a call at 2am in the morning, we get there, and they are using their own crusty lead and not the ones we supplied. The leads are always the weekest link.
    next is a switch or knob or function etc thats turned on or switched into the wrong position.
    Plugged it into the wrong output? sorry had to ask XD
  1. Unusual amp shut off problem....please help!
    By mike40370 in forum Car Audio
    Last Post: 12-05-2007, 05:13 PM
  2. Amp problem?
    By grottobill in forum Car Audio
    Last Post: 05-17-2007, 06:47 PM
  3. Mustang amp problem
    By Troteck in forum Car Audio
    Last Post: 05-14-2006, 11:58 PM
  4. Help hooking up subs and amp? Need advice...
    By jedi7001 in forum Car Audio
    Last Post: 05-17-2005, 02:28 AM
  5. FS: 2 mtx 10 inch subs and 400 watt amp with box
    By xdjxklusivex in forum Classified Archive
    Last Post: 02-25-2005, 04:41 AM
