Results 1 to 10 of 10
Thread: why do my front speakers bottom out?
    Feb 2008
    Here is my current setup
    deck
    http://www.crutchfield.com/S-kw4l6Lj...MP2035&tp=5684
    Front speakers
    http://www.sonicelectronix.com/item_...stics+S35.html
    Rear speakers
    http://www.sonicelectronix.com/item_...stics+S85.html
    Sub amp
    http://www.sonicelectronix.com/item_...L+CS300.1.html
    sub
    http://www.sonicelectronix.com/item_...S-W1207D4.html
    This system sounds awesome when I listen to rock, but when I listen to rap, my front speakers seem to clip/distort pretty bad at louder volumes. I went and got these bass blockers
    http://www.crutchfield.com/App/Produ...locker&tp=3216
    It helped a little, but not really all that much. Would my best bet be to get another amp for the speakers?
    For instance this one?
    http://www.sonicelectronix.com/item_...BL+CS60.4.html
    Will this eliminate my problem?
    _
    Mar 2004
    Little Elm, Texas
    It's because you're trying to get those speakers to play frequencies that are too low for them. They aren't designed to play that low. That's why subs exist.
    Without looking at that HU, I'm going to assume it doesn't have any kind of cross over function built in.
    Pick up a decent amplifier with built in cross overs and set the cross over for high pass (this allows only the higher frequencies to go through). Since you're using such small speakers up front, you need to set the high pass for 250 Hz or more. If the 4 channel amplifier that you get has the ability to set 2 channels at one cross over point and the other two at another cross over point, set the rears at 120 Hz or so high pass.
    Jan Bennett
    Newbie BasslineMilitia's Avatar
    Feb 2008
    New Zealand
    remember you wont always get that good performance out of teh front door speakers unless you put some effort into the enclosure. Usually there isnt enough air inside the door panel to enable decent bass.
    for clearer sound from yoru front crossing over your fronts will definaltly help like the guy before me mentioned
    _
    Mar 2004
    Little Elm, Texas
    3.5" speakers don't need that much air space....a bet a door is ample space for speakers of that size...and I'm no 'guy'...
    Jan Bennett
    Feb 2008
    New Zealand
    Quote Originally Posted by RedGTiVR6 View Post
    oops XD Forgive me *bows slightly
    You sure about tha air space? I've had soem soundstreams preform way better after a custom enclosure on the door to provide more air :0
    unless you talkign like 15W it wont make that much of a deal =\ or if you werent asking for more mid-bass
    Feb 2008
    It is actually front panel speakers and not door speakers, if that makes a difference.
    It's for an 86 dodge 600.
    can someone link me to a guide showing what you mean by crossover? Or how to go about setting them up in my car.
    ptk
    ptk is offline
    Singapore
    actually your deck's specs says
    Audio features:
    # System Q Sound Control (6 EQ curves and a 3-band equalizer)
    # "Supreme" audio processing for better sound from your compressed MP3 and WMA files
    # speaker settings that allow you to tailor the sound to the size and type of speakers in your car
    # low-pass filter on preamp outputs
    suggest try setting the speaker setting to "small after market speakers"
    CarPC Ver 4 completed. Aopen i45GMT-HD, C2D mobile 2GHz. Photofast 64GB SSD. Novatel EU-850D
    ptk
    ptk is offline
    Singapore
    Feb 2008
    Quote Originally Posted by ptk View Post
    yep I've had it on that setting sense day one.
    Feb 2008
    ok so I decided that I am going to go and get that 2nd amp. What else will I need wire wise and whatnot to get this installed?
  1. Why not PC speakers?
    By checksum in forum Car Audio
    Last Post: 11-27-2011, 09:29 PM
  2. I think i blew my speakers...not sure
    By senseless228 in forum Car Audio
    Last Post: 01-09-2008, 05:29 PM
  3. Radio only plays from front speakers
    By Uraijit in forum Road Runner
    Last Post: 10-31-2007, 09:37 PM
  4. 4ch AMP powering 6 speakers?
    By Alfredbra in forum Car Audio
    Last Post: 10-30-2007, 06:44 PM
  5. Only works front speakers
    By JosepZ in forum MediaCar
    Last Post: 01-16-2005, 05:52 AM
