Results 1 to 10 of 18
Thread: Installed new stereo/speakers, have problems, please help
    Mar 2008
    Hello,
    I recently purchased a JVC KD-HDR1 and had it installed by circuit city. I also replaced the front door speakers with Pioneer A-1682R, then the rear speakers with Infinity Kappa 692.7i. After I installed the rear speakers, I tested them before I put everything back together and they sounded fine. The next day as I was driving to work all of the speakers cut out on me. I tried messing with the wires and discovered that if I connect both of the wires to the left rear speaker the system will not work at all. If I have only one wire connected the system will work but cuts out if I turn the volume up too high. My fade and balance also seem to be out of whack. I am a total novice in this area so I need help to fix this. I don't think these speakers should be too much power for my system to handle but I really don't know.
    Thanks,
    samcoffeeman
    Car Audio Moderator durwood's Avatar
    Sep 2006
    Chicagoland (St. Charles,IL)
    first, this forum is about installing carputers just so you know. THere are plenty of other forums about car stereo.
    Second
    Your kappas are listed as:
    "2-ohm impedance"
    Why Infinity did this is amazing to me. They then say they are compatible with all aftermarket radios. That is completely stupid and false adverstising. I don;t know of any aftermarket radio that can handle 2ohm speakers. If they don't offer a 4 ohm version I'd return them and find a pair that does.
    If your fader and balance are screwed up, Take it back to circuit city, they did the install.
    Variable Bitrate rijk's Avatar
    Feb 2007
    netherlands
    wireing?
    trie to connect the speakers outside the car (with other wiring) if they sound good than check te wiring (litle battery on one and with a voltmeter on the other and of the battery) the other and of the voltmeter on the other and of the wire, the voltmeter shows the voltage of the battery, this is good, if it doesn't the wireing is broken..
    Also put the other and of the voltmeter on a metal part of the car, if the voltmetert than shows the voltage of the battery the outside of the wire is broken..
    Also put the voltmeter to the other wires, they should be 0. Do this with al the wireing to the rear speakers.
    Maximum Bitrate Woofnstuff's Avatar
    Oct 2007
    Auckland
    also check none of the speaker wires/connections at speakers are connected or touching metal. also what he said
    Nov 2006
    MAKE SURE that the speakers aren't touching the metal of the car. A speaker CAN'T WORK ON ONE WIRE OR ONE CONNECTION!
    You need to take EVERYTHING apart then put it back in. this time following the instructions.
    Maximum Bitrate boomintrac's Avatar
    Apr 2005
    2hr west of Chicago
    Just curious, what would happen if the speaker touches the metal part of the door?
    Aron
    New Ipad
    Zapco DSP-6SL
    Zapco Reference 360.4: H-Audio Soul, x2 right side
    Zapco Reference 360.4: H-Audio Soul, x2 left side
    Zapco Reference 500.1: JL Audio 10W3V3 Stealth box
    Maximum Bitrate JimmyFitz's Avatar
    Nov 2005
    Austin, Texas
    Quote Originally Posted by boomintrac View Post
    Aron
    The frame of the speaker is ok. But neither of the two wires going to any speaker can be grounded.
    ~Jimmy
    Mar 2008
    i had this problem with some subs. it ended up that the ohms in my subs were too low for my amp. I had some stuff run in parallell that needed to be ran in series
    Maximum Bitrate pRoFiT's Avatar
    Apr 2005
    Fresno, CA
    Sounds more like the speaker is shorting out. If you disconect one side and it still works then it must be getting a ground from the chassis. I would take it back to Circuit City and have them fix it.......Woops just read again....Um, Maybe you can bring it to circuit city with everything connected and tell them the stereo went out and see what they find. Kind of leave out the part about your new speakers until you really have to tell them that its all your fault the system isn't working
    Older audio systems use the cars chasis for ground and only run one wire back to each speaker. If this is the case then you may need to run new speaker wires to the back of the car.
    You may also just flip the back wires to the speaker. to see if that fixes it. Could be that when you replaced the speakers you put - on + and + on -. Then on top of that audio ground is connected to chasis ground......I dont know.
    Check wiring, Flip wires. Pull one over on circuit city
    Um, I guess this is where you put something witty.WITTY
    My Web site, in the design stage. http://home.comcast.net/~cstrachn
    Modified RRSkinEditor http://www.mp3car.com/vbulletin/rr-skins/65723-rrskineditor-bugs-fixes-comments-current-progress-outdated.html
    _
    Mar 2004
    Little Elm, Texas
    thread moved to the car audio forum.
    Jan Bennett
  1. Replies: 5
    Last Post: 03-02-2008, 06:07 PM
  2. Replies: 2
    Last Post: 01-31-2008, 03:15 AM
  3. Problems installing Girlfriend 1.0...
    By gospeed.racer in forum Off Topic
    Last Post: 10-18-2005, 06:17 PM
  4. mini carputer plus more GPS software installed for sales.
    By lockylocke in forum Classified Archive
    Last Post: 07-10-2005, 05:48 PM
  5. INSTALLED, but with problems
    By ericdee in forum Newbie
    Last Post: 05-05-2004, 10:01 PM
