Results 1 to 6 of 6
Thread: Flat Subs
    Maximum Bitrate Injector's Avatar
    Mar 2005
    Rockledge, FL
    Flat Subs
    I have been toying with the idea of installing a sub into my car now that i finished the carPC, i still have my old kicker L7 which is in a huge box because it's whats the speaker requires, now i don't know if i'm getting old or what it is, but now i don't want soo much base that it'll make my teeth shake nor do i want to loose my trunk space which are both a side effect on an L7, so i've been looking around for small flat subs which just compliment the pioneer stock speakers that came with my car, this leads me to my 2 main questions:
    1. does anyone have experience with them or know how they sound.
    2. this is more of a request, could you post any links to retailers selling them? because i've been having some trouble finding a good retailer which sells them.
    THNX.
    FLAC greatwhite's Avatar
    May 2007
    Top o' the world Ma!
    Leonardo Da Vinci
    Jun 2006
    Calgary, Alberta
    Blog Entries
    1
    Check out this sub:
    http://www.partsexpress.com/pe/showd...number=264-862
    The rms rating is low, but this appears to be a very efficient sub. Mine is mounted in a sealed 0.8 cu.ft box and I feed it power from an amp capable of 150wrms. Not much power, but wow, this sub is capable of being louder than I need it to be. I would describe the sound as being able to hit very low, yet still sound punchy and smooth.
    MySQL Error scott_fx's Avatar
    Dec 2004
    Los Angeles Ca
    Quote Originally Posted by Injector View Post
    THNX.
    i can't speak highly enough about parts express and that tang band woofer is pretty similar to the ed low pro sub.
    there are plenty of full size subs too that dont take up a lot of space. if you do a search for diyma sub on ebay it'll bring up a 12" sub that only takes .5 cu/ft and concentrates on quality of sound not boomy bass
    New System in progress:
    M10k
    Phaze TD1500 ~> Seas g18rnx/p
    Zapco Ref 500.1 ~ 12" tc-9
    Transflective Xenarc
    My Car Pc Install
    My Boat Pc worklog
    Maximum Bitrate boomintrac's Avatar
    Apr 2005
    2hr west of Chicago
    Scott is that the DIY sub you speak of or an IDQ?
    I run the elemental designs sq10 currently, its a decent sub and sounds alright in a .4fts sealed enclosure with 500 watts on it. Specs are almost the same as the Tang Band sub.
    New Ipad
    Zapco DSP-6SL
    Zapco Reference 360.4: H-Audio Soul, x2 right side
    Zapco Reference 360.4: H-Audio Soul, x2 left side
    Zapco Reference 500.1: JL Audio 10W3V3 Stealth box
    Dec 2004
    Los Angeles Ca
    Quote Originally Posted by boomintrac View Post
    http://cgi.ebay.com/Diyma-Sound-Qual...QQcmdZViewItem
    M10k
    My Car Pc Install
    My Boat Pc worklog
