Results 1 to 5 of 5
Thread: 3.5mm to RCA
    Maximum Bitrate Injector's Avatar
    Mar 2005
    Rockledge, FL
    3.5mm to RCA
    i've been looking for an adapter that will turn 3.5mm which is just a regular headphone connector into RCAs, but i'm looking for the 3.5mm connector to be a female not a male like this
    Maximum Bitrate Woofnstuff's Avatar
    Oct 2007
    just goto your local electronics / gadget shop
    buy a normal 2xrca to 2xrca, chop the plugs off and solder 2 of the ones you want on. then you get 2 cables
    they might even have the cable you want pre made
    if our local electronics store has it anyone should
    this sort of thing?
    Maximum Bitrate pRoFiT's Avatar
    Apr 2005
    Fresno, CA
    Like these? I got 3 of them
    I may even have female 3.5mm to female RCA's somewhere. And no there mine
    Um, I guess this is where you put something witty.WITTY
    My Web site, in the design stage.
    Modified RRSkinEditor
    Mar 2005
    Rockledge, FL
    well both of you guys got exactly what i need, the only store around here that could come anywhere close to have those cables is radio shack and they don't have it, where did you guys get them?
    Constant Bitrate ronjon228's Avatar
    Dec 2005
    Grand Blanc, MI
    Ebay is your friend. Especially when it comes to little stuff like this. I'm sure it will be there AND be dirt cheap.
    1.8GHz Northwood, Intel 845 Mobo, 512MB DDR, 1x20GB + 1x160GB, Intel GPU, SB Live 5.1
    Sound System:
    Phoenix Gold RSD 65cs 6.5" Drivers, Infinity Tweets, Pioneer 305DVC 12", PPI Sedona 630IX, Alpine MRP-M500
  1. Replies: 5
    Last Post: 01-14-2008, 02:37 AM
  2. Replies: 5
    Last Post: 10-12-2006, 11:25 AM
  3. Needed a good source 3.5mm to RCA shielded audio cable
    By bosstone74 in forum Classified Archive
    Last Post: 01-16-2006, 06:28 PM
  4. minimum distance between power & rca wires
    By michaelrj9 in forum Car Audio
    Last Post: 08-30-2005, 02:02 PM
  5. Replies: 8
    Last Post: 06-03-2001, 09:16 PM
