View Poll Results: Bass or Quality?
Voters
37. You may not vote on this poll
  • IASCA winning bass?
    2 5.41%
  • audiophile clarity?
    35 94.59%
Page 2 of 4 FirstFirst 1234 LastLast
Results 11 to 20 of 40
Thread: Bass or Quality?
  1. #11
    _
    Mar 2004
    Little Elm, Texas
    how about IASCA/USACi winning Quality?
    I think we all know what I prefer.
    I'll agree with Scott here...it would be better to save your money and get a decent set of components than to spend all your money now because you just can't wait.
    Jan Bennett
  2. #12
    Nov 2006
    Arizona
    Quote Originally Posted by scott_fx View Post
    nice equipment :-)
    one question... why the 4" speakers? are they in the rear? seems like those are the week point of your system
    In camaro's there are 6.5" in the doors, and 6.5" in the "sail panels" which is like right in the ear of the person in the back seat and then the 4" speakers are in the hatch/truck area... so all of the sound will be coming from the 2 in the doors and the 2 in the sail panels, the ones in the rear are just to fill it all in from front to rear.
    2001 Camaro SS #2070
  3. #13
    Constant Bitrate Pathos's Avatar
    Jun 2004
    St. Louis Mo.
    I like SQ and used to pound my subs when I was 18 also but I like SQ better (and not that linear graphed stuff either....a totally flat lined freq response does not sound very good in my car but it doesn't in most)
    "A rose by any other name is still a flower"
  4. #14
    MySQL Error scott_fx's Avatar
    Dec 2004
    Los Angeles Ca
    Quote Originally Posted by ronjon228 View Post
    Yea, as I said, I just went active and really didn't know what to set things at. I did some research and found that my 5.25" comps go down to 67Hz on the low end. Should I set my x-over at this? Or set it higher to compensate for the curve?
    Also, about the EQ, I really don't like messing with an EQ too much. Seems most people just jack their EQ's up so bad that it makes everything sound muddy and generally not so great. For tuning an EQ what would you suggest? How much variation should I have (+/- dbs). Also, I always thought it was best to leave the EQ flat because when music is produced they do all the EQ work at the studio. Let me know what you think because I'd love to hear more.
    It's cool, i'm always learning as well. it's awesome that you're going active.
    there is a post in the car audio faq or somewhere on this site on how to tune your system usinga $45 radio shack db meter, very cool post... check it out.
    67hz still seems low depending on the power you're giving them. I bet they fall off quickly. I would probably start around 80 hz and see how they sound. my old 6.5" cdt's would fall apart with anything below 80hz. If you're door is well dampened and you're not throwing a lot of power at it then you may get ok results that low, but it wont be that loud before it starts to distort. Start at 80 hz (with sub turned off) and see how it sounds then play from there.
    Quote Originally Posted by CoryF View Post
    i think i'd still delete the 4"s and probably minimize the volume to the sails unless you have passengers back there. focus on just front left, front right, and sub and you'll probably get better results. imho
    Quote Originally Posted by WuNgUn View Post
    You too!!!
    How do you like those SEAS?
    i'll tell you when i actually get this thing finished :-\
    i already starting collecting components for my daily driver and will be including a seas neo tweeter in that install.
    New System in progress:
    M10k
    Phaze TD1500 ~> Seas g18rnx/p
    Zapco Ref 500.1 ~ 12" tc-9
    Transflective Xenarc
    My Car Pc Install
    My Boat Pc worklog
  5. #15
    Variable Bitrate brucedog's Avatar
    Oct 2007
    Philadelphia, PA
    It's interesting reading what you guys are saying about active tuning and also about high-line speakers / components.
    As a re-beginner in car audio who was used to 1970's speakers, tape players and such, pretty much any amps, speakers of this century sound remarkable better. Really.
    I just have 2 Pyramid amps, and a Buttkicker sub amp. Generally loud and clear, with that great bass, but with vocals and instrumental solos verrry clear.
    Speakers are a MA Audio 2x10" box, and really you should look at my pictures for the others...really strange based on what y'all are doing. Bottom line, my sound is really nice, especially with a great quality cd ripped to my carpc Hd on...
    But when I hear you speak of time and phase correction, and audiophile op amps on sound cards, I maybe thing I want to go there.
    [/IMG]
    [/IMG]
    Happy CarPC'ing!
  6. #16
    Constant Bitrate ronjon228's Avatar
    Dec 2005
    Grand Blanc, MI
    Are you using home audio speakers in there? Haven't seen that done in a LONG time. If you are, you'd benefit greatly, I would think, from having stuff geared more at car audio. Home audio components are meant to run at 8ohms primarily and, from my experience, sound way too treble heaving in a car environment.
    Also just in general it seems you have too much going on. When it comes to car audio a lot of time, less is more. Your front stage is paramount. A nice 6.5" or if you can't fit that 5.25" component set is perfect really. Then some rear fill can consist of something as little as some mid-range drivers. Your subs should be fine. With 2 subs though, if you can do a 6.5" comp set up front, and some 6.5" drivers in the back I think you'll really like the way it sounds.
    CarPC:
    1.8GHz Northwood, Intel 845 Mobo, 512MB DDR, 1x20GB + 1x160GB, Intel GPU, SB Live 5.1
    Sound System:
    Phoenix Gold RSD 65cs 6.5" Drivers, Infinity Tweets, Pioneer 305DVC 12", PPI Sedona 630IX, Alpine MRP-M500
  7. #17
    Dec 2005
    Grand Blanc, MI
    Will do man, thanks for the advice. I've got a nifty little setup on my desktop right now for tuning and it makes things a piece of cake. If I minimize FreeIce, my front crossover, rear crossover, and subwoofer volume control right on the desktop for on the fly tuning. I'll try 80Hz and go from there.
    I've actually got another question for you. Since I'm running 6.5" drivers in the back deck, they want to overpower my 5.25" drivers in the front unless I cross them over at a higher Hz. Am I hurting my SQL by crossing these over at a higher range than the front fill? Should I just compensate more with the fader instead? If I leave them all zeroed out, it definitely throws my sound stage off. The fronts are more heavy on treble (with the tweets) and the rears are more heavy on the mid-range. Therefore I get 2 sound stages without altering this. A "treble" stage in front, and a "mid bass" stage in back. That's why I'm crossing them over at a higher frequency right now.
    About this db meter and tuning, it's something I'll definitely check out. Thanks for the tip.
    CarPC:
    Sound System:
  8. #18
    Maximum Bitrate Megalomaniac's Avatar
    Jan 2006
    The Colony, TX
    Quote Originally Posted by brucedog View Post
    [/IMG]
    [/IMG]
    not my cup tea at all, but im glad you are satisfied.
    i voted Quality. however at one point all i wanted was bass but grew over it pretty fast when i realised i dont like too much bass
    screen name here use to be MegaloRESE15"
  9. #19
    Nov 2006
    Arizona
    Ya, once it is all in then i got a lot of tuning to do. There will not be any stock stereo in the car, its like starting from scratch. haha gotta love this stuff!!
  10. #20
    Oct 2007
    Philadelphia, PA
    Thanks ronjojn and mega.
    Yeah, that's what is funny for me about is new car audio experience. As an old head, it wasn't possible in the 70's to get any sort of high-quality sound in the car, so some of us actually brought bookshelf (box) speakers into the car, installed inverters, and (yes) actually monted some kind of Kenwood or Marantz or Tecniques receviver under the dash.
    Looked strange, sounded awesome - people wouldn't ride in my car bacause it was "too loud!"
    So, I guess the stuff I've got in this car are sort of a retro holdover to those old days - go with whatcha know best...
    Although it sounds really nice in my car, 'm thinking that I should look into what kind of car audio magazines are out there, and get a couple to learn what's current. Also, howbout a book or two on high-end car audio?
    Thanks for the introduction to a better way. Suggestions are always heard.
    Happy CarPC'ing!
  1. Replies: 24
    Last Post: 02-19-2008, 01:03 AM
  2. Hibernation / Resume issue with PhoCo
    By zorro in forum Centrafuse
    Last Post: 10-09-2007, 01:21 AM
  3. System Choices and Questions
    By BoondockSaints in forum Car Audio
    Last Post: 08-09-2007, 10:52 AM
  4. Bass channel not loud enough
    By spoonraker in forum Car Audio
    Last Post: 01-14-2007, 09:18 PM
  5. How do you control Bass??
    By PhatMo in forum Car Audio
    Last Post: 06-16-2006, 10:09 PM
