Results 1 to 10 of 17
Thread: Are there any restrictions about the angle of radio installation?
    Nov 2007
    Hey guys. I'm thinking about my radio relocation so the question is: Are there any restrictions about the angle of radio installation? I want to install it vertically into my center console hand rest but I'm not sure if the radio can work properly being installed like that. Any ideas?
    Thanks in advance.
    Maximum Bitrate Snootch's Avatar
    Sep 2003
    Tampa, Florida
    There should be no problems with mounting it vertically. The radio should not be affected as long as you are plugging the antenna into it. (i'm assumming you are using the stock antenna)
    WORKLOG
    Asus P5N73-AN Mobo/Celeron E1400 2Ghz Dual Core CPU/2Gb GEIL PC3200/120GB HDD/DSATX PS/8" Phylon TS
    Webpage
    FLAC greatwhite's Avatar
    May 2007
    Top o' the world Ma!
    Does it play CD's?
    Not having it vertical may effect it depending on how it is built. Even a cd player radio should work mounted vertically, but no guarantees. The radio will work fine if that's all you're concerned about.
    Why don't you hook it up and hold it vertical in your hands to test it? If it works there, feel free to mount it however you wish.
    Cheers
    Leonardo Da Vinci
    Nov 2007
    well. obviously the radio (am, fm) will work fine. I''m talking about CD playing of course. I wanna keep my CD player along with carpc, but I have to either install palyer into glove box or into hand-rest.
    Well, it's gonna take me a while to test-drive it in vertical position and since it''s my daily driving car, well.. you know Maybe I will just mount it into glove box. Not sure yet... My car is petite ))) not too much space to play around.
    May 2007
    I'm pretty sure it will work fine vertically, but you have to find a way to test it before you can be sure.
    Just pull the player out of the dash and see if there's enough slack in the factory harness to let you hold it vertical. Take you about an hour from removal to reinstall if you take your time.
    Good luck
    Leonardo Da Vinci
    Nov 2007
    it''s not a first time I''m playing with radios ) I mean - installation, but I have never tried installing them in locations other than stock DINs )))
    I know there are some restrictions for CD changers but I don''t know if it applies to Single CD Players as well... I guess I will have to try then )))
    Maximum Bitrate JimmyFitz's Avatar
    Nov 2005
    Austin, Texas
    If you really expect to get meaningful advice, it might be advantageous to give more information with your question. Some details like what kind of car, what country you live in, etc.
    ~Jimmy
    Maximum Bitrate boomintrac's Avatar
    Apr 2005
    2hr west of Chicago
    It should work but will most likely skip quite a bit over smaller bumps.
    Aron
    New Ipad
    Zapco DSP-6SL
    Zapco Reference 360.4: H-Audio Soul, x2 right side
    Zapco Reference 360.4: H-Audio Soul, x2 left side
    Zapco Reference 500.1: JL Audio 10W3V3 Stealth box
    MySQL Error scott_fx's Avatar
    Dec 2004
    Los Angeles Ca
    Quote Originally Posted by JimmyFitz View Post
    how does what country he lives in have any affect on if his cd's will play in his head unit?
    New System in progress:
    M10k
    Phaze TD1500 ~> Seas g18rnx/p
    Zapco Ref 500.1 ~ 12" tc-9
    Transflective Xenarc
    My Car Pc Install
    My Boat Pc worklog
    Variable Bitrate Nerd2's Avatar
    Dec 2006
    Bristol/Cambridge, England
    Mine Ford CD player is mounted vertically in the centre console - no problems.
    Can't SEE what track its on though
  1. Class 2 Data Bus
    By owenjh in forum Engine Management, OBD-II, Engine Diagnostics, etc.
    Last Post: 10-09-2008, 04:34 AM
  2. need radio help
    By anniechick in forum Car Audio
    Last Post: 04-09-2007, 11:54 AM
  3. MP3 Player to GM Factory Radio
    By thewams in forum Newbie
    Last Post: 04-01-2007, 03:46 PM
  4. Replies: 10
    Last Post: 03-19-2007, 05:45 PM
  5. Replies: 2
    Last Post: 05-02-2006, 06:15 PM
