Results 1 to 3 of 3
Thread: Auzentech Card: can't get sound out of the sub channel (again)
    FLAC Nola111's Avatar
    Jan 2007
    New Orleans, LA
    Hey all,
    I'm having issues getting sound to my sub out of of my Auzentech Prelude card. Since it uses Creative software, I followed the instructions in the following post that I found by searching...
    getting sound to the subwoofer
    The key was using a y-splitter, and lo and behold, I got sound to the sub! Good right? Well no, because after two days, the card stopped sending the signal to the sub. (I know it's not the sub b/c I hooked an mp3 player to it to test it... the sub is fine).
    The absolute only thing I did between the time the sub worked and didn't work, was install RoadRunner. (I use Centrafuse mainly). Installing RR couldn't have done anything, huh? So now, I've gone over and over and repeated the steps in the above post, and I can't get sound out of the sub/center channel of the card.
    Does anyone have any ideas of something else I should try?
    Thanks!
    Oct 2006
    Bear, DE, USA
    Quote Originally Posted by Nola111 View Post
    Hey all,
    Thanks!
    You know, I've had to fight with Creative software in the past and making sure it reads the same in terms of speaker setup (4.1, 2.1, 5.1, etc.) as it does under Windows speakers/audio control panel. Start from Road Runner/Winamp, move to creative setup, then check the control panel, in each place making sure that your speaker layout is reflected correctly.
    I have too much time and too little aggravation in my life, so I built a carPC. ;)
    Jan 2007
    New Orleans, LA
    Hi there hithere. Thanks for the reply. Actually, I don't even think I'm going to use RR anyway, mainly Centrafuse. It worked fine in there for awhile and now nothing. I would uninstall RR, but for one, I can't see how installing RR would have mucked something up that bad, and two, I still would like to have it on my system even though I won't be using it as my main F/E.
    What's strange is that I followed durwood's instructions, got it working, and now nothing, even when repeating durwood's instructions.
    The software is a little bit different from older Creative cards but for the most part it has all the same, or similar settings. In fact, the software I have has an option to boost the subwoofer output by +15db... in the same section that the "Enable Bass Redirection" option is in. Having both those ticked really did the trick last time. Now, nothing.
  1. Core Duo / Core 2 Duo Mini-ITX boards
    By RedGTiVR6 in forum General Hardware Discussion
    Last Post: 10-03-2010, 10:30 PM
  2. usb sound card
    By gti4dr in forum General Hardware Discussion
    Last Post: 10-16-2007, 07:24 AM
  3. Advise on usb sound card
    By Kimota in forum General Hardware Discussion
    Last Post: 09-11-2007, 01:45 PM
  4. Replies: 5
    Last Post: 02-03-2005, 01:43 PM
  5. Sound card reccomendation for **music**
    By TWBarrett in forum Car Audio
    Last Post: 09-09-2004, 09:40 PM
