Results 1 to 5 of 5
Thread: Subwoofer, quick question....
    Ireland
    I've bought a new headunit and have everything wired and hooked up except the switch signal that hooks up to the ACC on the the back of the headunit. I guess its the line that goes to ground when the key is not turned in the ignition.
    Anyway i noticed that the red/white sub output cables have another small wire running the along them that I had ignored before now. I assumed it was something to do with grounding and I ignored it.
    Its a very thin piece of wire, can I used this to send the ACC signal to the sub to switch it on or off?
    thanks in advance!
    Feb 2008
    Quote Originally Posted by quarryman View Post
    thanks in advance!
    Thats exactly what it is for. It is the remote switch wire that turns on your amp. I put a thicker wire to do that, but what you have will work.
    It connects to the amp and then on the receiver it connects to the blue wire with the white line on it. Then youre good to go!
    Constant Bitrate ronjon228's Avatar
    Dec 2005
    Grand Blanc, MI
    While fbcbeer is right, I will add something. Your remote wire can be basically any gauge. Size doesn't matter as it's just a signal wire, it carries minute amount of current.
    CarPC:
    1.8GHz Northwood, Intel 845 Mobo, 512MB DDR, 1x20GB + 1x160GB, Intel GPU, SB Live 5.1
    Sound System:
    Phoenix Gold RSD 65cs 6.5" Drivers, Infinity Tweets, Pioneer 305DVC 12", PPI Sedona 630IX, Alpine MRP-M500
    Feb 2008
    Quote Originally Posted by ronjon228 View Post
    The reason why I went with a little bigger wire (18 guage) is because I didnt want the tiny signal wire between my RFosgate RCAs to kink and stop the signal at any point.
    Either way will work great!
    Ireland
    Bit late now, forgot to reply!
    Went with the small gauge cable and it worked perfect!
    thanks.
  1. Subwoofer boxes / cases - quick question
    By Pabs in forum Car Audio
    Last Post: 12-02-2004, 03:24 PM
  2. Quick question on kiosk
    By Gavc in forum General Hardware Discussion
    Last Post: 11-10-2004, 10:16 PM
  3. Quick grounding question
    By GingerPrince in forum Power Supplies
    Last Post: 11-06-2004, 09:28 PM
  4. quick question about dc voltage
    By cdm in forum Power Supplies
    Last Post: 03-05-2004, 04:19 AM
  5. quick fuse question....
    By jusatry in forum General Hardware Discussion
    Last Post: 02-23-2004, 11:54 PM
