you have a lot of options and probably a lot of higher quality options as well. do a search for 'dac' or look at some of the stickies.
I'm running a Aopen mini pc onboard sound going to car amplifier and as some of you know, some noise gets introduced from the hard drive, gps nav receiver, or what not. I'm gonna try and isolate the noise by using the SPDIF output port.
Question on the Sound Blaster Audigy 2 NX card's optical in/out.. If you feed audio to the line in (via 3.5mm plug) does that get come out of the optical out port or no?
New System in progress:
M10k
Phaze TD1500 ~> Seas g18rnx/p
Zapco Ref 500.1 ~ 12" tc-9
Transflective Xenarc
My Car Pc Install
My Boat Pc worklog
I have the same question about the use of a Sound Blaster Audigy 2 NX.
Sadly the stickies didn't yeild anything I could use, i'll keep looking
THis was a good start
Audigy 2 NX
New Car PC Build list in progress
M10k
My Car Pc Install
My Boat Pc worklog
I do believe the NX has a coax digital 3.5mm input port, but I think what he's asking is if the sound card will do a A/D conversion from it's line in and output over optical. And it's not pointless, if you're trying to consolidate multiple inputs, either digital or analog, to a single optical due to equipment limitations on the other end. For example, you have an amp or processor with a single digital input and you have multiple sources which include a PC (sat radio, HD radio, etc.). I know because I was trying to do something similar at one point...
In answer to the OP, if the above is what you're asking, I believe it's possible, but I couldn't find any way to make it work reliably on my Audigy 2 NX...
I have too much time and too little aggravation in my life, so I built a carPC. ;)
M10k
My Car Pc Install
My Boat Pc worklog
i guess i should have rephrased that, does his amp have digital input
M10k
My Car Pc Install
My Boat Pc worklog
For owners of the 2 NX card, if you feed it audio off the 3.5mm line in jack, it will output that off the S/PDIF output. Just a fyi.
My carpc worklog
