Page 1 of 3 123 LastLast
Results 1 to 10 of 22
Thread: VenHaus braided speaker wire pic!
    FLAC WuNgUn's Avatar
    Sep 2007
    Here is a shot of my, just finished, sub speaker wire (for single 10")...
    It's equivilent to 10 gauge...
    You can see beside the 14-16 gauge driver wire just how robust it is!
    It's basically 3 driver wires braided together. Thank God I only needed a short run!
    And a pic of the wire for use off the crossover to the tweeter...
    And what I had to work with...
    Mo' Programming Mo' Problems
    Sonicxtacy02's Avatar
    Woodbridge, VA
    Blog Entries
    43
    and this does what?
    Live mp3Car Facebook Chat
    mezz64's Avatar
    Nov 2004
    PA
    Blog Entries
    1
    First question, stranded or solid, it looks solid in the photos. If it's solid I'd be concerned how well that is going to hold up in a car environment. And along the same lines I'd be all for such an elaborate cable in a home setup, but do you really think the difference will be evident in a moving vehicle?
    Just my 2 cents.
    Jun 2006
    Calgary, Alberta
    Blog Entries
    1
    I think he is braiding cat5 cable like that to make the cable low inductance and improve audio quality (faster signal risetime I think?). I doubt it is humanly possible to actually hear a difference though.
    Sep 2007
    Maybe, maybe not...
    But there are plenty of reviews available...
    And in a environment as noisey as a cars, wouldn't you want to try and achieve the best audio reproduction you can because of this fact??
    I mean, because it's not the best environment doesn't mean you can or should get away with 'so-so' quality, right?
    Oct 2006
    Bear, DE, USA
    I agree with the goal of achieving the best reproduction possible...but I have a real hard time believing that inductance is an issue for subwoofer frequencies assuming even mediocre speaker cable over anything less than miles of distance.
    Doing this for subwoofer speaker cable only further adds to the ridiculousness of applying inductance concerns to speaker wire in distances measured in feet. The inductance measured in such cable over those types of runs affects the audio in no audible way, as well as any effects being orders of magnitude below the speaker's own accuracy.
    I have too much time and too little aggravation in my life, so I built a carPC. ;)
    Maximum Bitrate boomintrac's Avatar
    Apr 2005
    2hr west of Chicago
    If he will be competing this is one of the detail things they will look at. If not others like veerything to look uniform, whats wrong with that? The end result will look much more like a finished product.
    Aron
    New Ipad
    Zapco DSP-6SL
    Zapco Reference 360.4: H-Audio Soul, x2 right side
    Zapco Reference 360.4: H-Audio Soul, x2 left side
    Zapco Reference 500.1: JL Audio 10W3V3 Stealth box
    Car Audio Moderator durwood's Avatar
    Sep 2006
    Chicagoland (St. Charles,IL)
    I'd be worried about how well that would hold up in the car. The insulation is very thin and can easily get snagged on sharp metal, even if you are trying to be careful.
    Second, let's assume such a great claim as "rise time". Rise time of what exactly?
    Anyone considering this, please do not blindly follow marketing but be willing to question the claims made.
    Any wire, over a short distance (meaning <500ft) can easily carry audio bandwidth signals between 20-20Khz. It can be calculated using R/L/C values plugged into basic filtering formulas.
    Mar 2008
    Well, braiding the wires does help with the signal. If you don't have braided wire you get magnetic fields and the like all messing up your signal.
    However, why not just buy some pre-braided 10awg? Its not that expensive and you wouldn't have to spend hours on it.
    Plus they are insulated with nice thick rubber.
    You are silly...
    Oct 2006
    Bear, DE, USA
    Quote Originally Posted by ArcaneDreams View Post
    Braiding wire can help minimize the wire's inductance characteristic...but, especially for low-end frequencies in the range of human hearing, for wire that is some feet (and not miles) in length, this is akin to cleaning old french fries from under your seats in order to reduce your car's weight and make it faster in the quarter-mile.
  1. Broken speaker wire
    By fluffy2097 in forum Car Audio
    Last Post: 12-06-2006, 09:47 PM
  2. RCA to Speaker wire?
    By greenglo in forum General Hardware Discussion
    Last Post: 02-16-2004, 02:20 PM
  3. Replies: 3
    Last Post: 02-15-2004, 09:57 PM
  4. ignition wire for opus psu
    By liquid_smoke in forum Power Supplies
    Last Post: 09-09-2003, 10:58 PM
  5. PSU power over speaker wire???
    By Defiler in forum Power Supplies
    Last Post: 02-20-2003, 06:48 PM
