Hopefully you did not operate the amp with no speaker connected to any particular channel. You must always have a "load" (speaker connected or the amp may blow. Most modern amps have sensing protection to cover you, but don't take chances.
To test the amp, always keep things simple:
>with the power off
>disconnect all speakers from the amp that have the problem - only keep the known good-sounding ones connected
>use your mp3 player as amp input music signal
>get some known good speakers out of the house or wherever...these will be connected to the suspect channels
>fire up the amp at low volume level, increase vol gradually and listen for problems
If the same bad noise is still there, your amp has blown something.
LinkBack URL
About LinkBacks
