You would need to take a multi tester and see where which connection from the aux in goes to the head unit, you can do this by taking a stereo 3.5mm plug and putting it in , unscrewing the head unit and checking where the connection comes it, then you just solder wires for the ground and left right.
(unless the faceplate has some kind of preamp or makes the signal digital)
LinkBack URL
About LinkBacks
