Results 1 to 10 of 10
Thread: Audio Hookup to Stock Speakers
    Mar 2007
    Hi all,
    I am planning a project and one of the questions i have is how would you hook up the stock harness to the PC?
    Would youhave to split it up and then Wire up a mini RCA/ RCA Cables to it to wire it up to the onboard sound on the MB?
    Mar 2007
    i did find this
    http://retailer.installationexcellen...roductid=11639
    but that would also have to rewired into the rca.....
    Maximum Bitrate pcpete's Avatar
    Mar 2008
    Toronto Canada
    Normally, you need an amp between the pc and speakers....
    Mar 2007
    but the question of interfacing the stock harness still stands....what do you plug in to the stock harness to convert it to rca etc...
    Feb 2008
    Line out converter?
    Mar 2007
    thanks...will look it up - i am such a newbie at this still
    Mar 2008
    Toronto Canada
    If you are going with an amp, presumably mounted in the trunk, you would connect pc-> amp with rca, amp directly to speaker wires.
    To connect to speaker wires you would have to run speaker cable from the trunk and either use a harness (like what you linked to) or splice directly to speaker wires in the stock head unit location.
    You really have to define what you want. ie amp or not / new head unit with aux in etc...
    Mar 2007
    Thanks for the info.
    I don't want an amp unless i really need to have one.
    I want to run the PC with a display in the dashboard and have it output sound into the stock speakers.
    So the question is do i really need an amp?
    Mar 2008
    Toronto Canada
    Something needs to amplify your pc output, be it your headunit or an amp.
    Think of your pc output the same as an ipod output, what would you need to connect an ipod to you headunit (which has an amp in it)?
    Mar 2007
    ok..so i definatelly need an amp then as i am thinking of not using any head usint at all since the PC will be able to play more types of media anyhow.
  1. BMW 330Ci 2003 Install keeping the stock audio ?
    By dexter4000 in forum Newbie
    Last Post: 12-11-2007, 10:45 AM
  2. Audio Interrupt "Black Box" for Stock Head Unit
    By jmciver in forum Hardware Development
    Last Post: 10-11-2007, 03:15 PM
  3. Replies: 5
    Last Post: 06-24-2007, 09:13 AM
  4. F/S - Infinity and Polk Audio Car Speakers!!
    By neema12 in forum Classified Archive
    Last Post: 07-23-2005, 06:27 PM
  5. Wiring portable audio speakers
    By st11x in forum Newbie
    Last Post: 02-04-2005, 12:47 AM
