Results 1 to 6 of 6
Thread: 2001 Corvette Stock Speaker Questions
    Newbie sydneyACE's Avatar
    Feb 2008
    So here's the setup, I have a 2001 Corvette coupe. I plan to put a pc in it. It would be great if I could use the stock head unit, but that wont work because I'm gonna put my screen there. I would like to retain use of the stock Bose speakers, I think they sound good. I would really like to have surround sound capability for watching DVD's in the car. I guess you would call this a 5.1 setup. Currently I have the PAC audio RCA output adapter (for my sub) it converts the stock HU signal into a set of RCA's for front and rear.
    So a couple of questions:
    Do you need a specific type of sound card to run a surround setup? If so what type?
    I've heard that the factory Bose speakers wont work without the stock HU. Is this true, or will the PAC audio adapter allow me to basically input whatever signal I want? (beacuse it splices into the stock wiring harness) I'm assuming if I go this route I will need to add an amplifyer.
    I would like to avoid running new wiring to the door/rear speakers if at all possible, I would also like to retain the Bose powered door "sub" as it adds nice mid-range base.
    Any suggestions are appreciated. Scott, I know you know the corvette sound system inside and out.
    MySQL Error scott_fx's Avatar
    Dec 2004
    Los Angeles Ca
    well, first thing i urge you not to go the 5.1 surround route. you really can't do that anyways without getting a dedicated center chan speaker and amp. you can use the pac adapter (or the soundgate adapter which is supposed to be of higher quality) to retain your stock woofers. that will allow you to retain the stock sub but you will need a small amp to power the other speakers.
    you could use the stock wiring but since the amp is in the back you're better off making new runs to the speakers. the corvette is the easiest car to run wiring in, i doubt it'll take you much longer to run wire to the doors then it would running wires from the amp to the harness behind the radio.
    my personal recommendation would be to dump the idea of keeping the stock speakers and the 5.1 setup and drop the rear speakers as well.
    since you were planning on running the 4 stock speakers you were going to need a four chan amp and a bose interface. Stick with the 4 chan amp, now the bose interface is about $100. if you put that money towards raw drivers such as:
    http://www.partsexpress.com/pe/showd...number=295-364
    which are on sale right now for $31 each
    and then buy some seas neo tweeters (or northcreek tweeters) for about the same. you are going to achieve far far superior sound for about $25 difference.
    here is some ref:
    http://www.zaphaudio.com/tweetermishmash/
    New System in progress:
    M10k
    Phaze TD1500 ~> Seas g18rnx/p
    Zapco Ref 500.1 ~ 12" tc-9
    Transflective Xenarc
    My Car Pc Install
    My Boat Pc worklog
    Feb 2008
    Scott you're the man! Thanks for your help. Couple more questions: Those Dayton 7" will fit in the door? Do I need to get aftermarket door adapter plates? Or will they fit where the stock speakers reside? Can I use the factory rear speakers, and just run new wires to them from a 4 channel amp? Also what kind of usb sound card do you recomend? I've decided to ditch the idea of surround. Do I need to use a crossover for the door/rear speakers? Sorry for all the questions, they might be answered somewhere else, but I figured if you have the time, you could help me out. I know you have gone through all of this already. Thanks again
    Dec 2004
    Los Angeles Ca
    you need door adapter plates, easiest thing to do is remove the bose plate from the door, then tape some paper over the hole leaving some overlap. then use a razor to cut out the rough opening of the hole you just covered. now mount the bose plate back on the door and trace the outline on the paper. remove the bose plate and there is your template with mounting holes (made when you screwed the bose plate back on) now get some 1/4 mdf a cut out the shape. this will give you a plate for you to mount your speakers too. all you need to do is cut the speaker hole and mount them. while you have the door off it's a great time to cover up the big hole toward the back of the door. you can get some masonite from home depot and use that to better seal up your door. you'll have to shave down the styrofoam a bit on the door but nobody will ever know. :-)
    the 7" will fit w/o a problem. i have 7" in there now and there are a handful of people using 8" woofers as well.
    you'll need all 4 chans for the setup i've suggested. you aren't relying on a passive x-over with that setup, you'll be doing the processing on your computer. you can pump plenty of power to those speakers and as long as you sound deaden your door you'll get some deeper bass. rear speakers just make tuning harder and doesn't really add much except for overall spl imho. for the next few weeks drive around w/o rear speakers and once you get desensitized to not having rear speakers you'll realize that the soundstage has been improved. with your new speakers and amp you'll be able to make up in spl what you lost by deleting the rear speakers. i'd say 85% of the guys over at corvetteforum are running systems w/o rear speakers.
    as far as usb soundcards, i'm not really up to date on soundcards anymore so you'll have to research that yourself.
    M10k
    My Car Pc Install
    My Boat Pc worklog
    Feb 2008
    Are you using a 7" "sub" in the door, or a "full range speaker"? I would like to use elemental audio components because that's what kind of amps I'm using, and that's my sub type too. "full range" http://www.edesignaudio.com/product_...products_id=49 or "sub" http://www.edesignaudio.com/product_...products_id=33 Thanks again
    Travis
    Dec 2004
    Los Angeles Ca
    if you're going to go the prebuilt route then go with the full range. those subs have very limited use and value. definitely the wrong choice for your application. If you go the route i suggested earlier; with a little tuning, you'll have a far superior sounding system then you will with the component systems made by ED
    M10k
    My Car Pc Install
    My Boat Pc worklog
  1. Amp and Speaker Questions
    By unixxx in forum Car Audio
    Last Post: 02-24-2006, 04:52 PM
  2. Questions re: my Carputer amp, EVIC, etc.
    By vettejock99 in forum Car Audio
    Last Post: 09-07-2005, 03:39 PM
  3. Replies: 6
    Last Post: 05-25-2005, 11:53 AM
  4. ****PIC ! CDT CL-61 6.5" New Car Speaker Comp !PIC ****
    By neema12 in forum Classified Archive
    Last Post: 12-19-2004, 05:44 PM
  5. Replies: 19
    Last Post: 07-03-2004, 07:39 AM
